Author Topic: Who sells ss brake lines?  (Read 1652 times)
andmoon
« on: May 07, 2008, 12:40:49 PM »
I can't find any for my 550k0
Offline cbass*gxc
    • My Pics Page
Re: Who sells ss brake lines?
« Reply #1 on: May 07, 2008, 12:56:04 PM »
http://www.spieglerusa.com/
Your best bet is to call them.  Try them or HEL USA.  They both make a good brake line and will be able to make what ever you need.
Offline alltherightpills
« Reply #2 on: May 07, 2008, 02:43:41 PM »
Depending on where you are, you could find a local hydraulics or custom hose shop and have them custom made for you.  Just take your old lines in and they will make a replacement.  I got my ss lines for my 78550k for 40 bucks, which is 60 bucks cheaper than HEL.  Granted, I had them make one line to go from the master to the hard line on the caliper and removed the splitter block that actuates the brake light.  I always use both brakes, so I figured this wouldn't be a problem.
Zach
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
eldar
« Reply #3 on: May 07, 2008, 04:30:31 PM »
Did you get 1 line or 2? I got 1 line from master to caliper for 50 including all the hardware. 100 was for a dual line front end such as on an F.
ev0lution7
« Reply #4 on: May 08, 2008, 05:47:24 PM »
what size is the Steel line that goes from the flex hose to the caliper what thread pitch 1.25 or 1.0?
Offline Alan F.
« Reply #5 on: May 08, 2008, 05:59:48 PM »
I've been doing some searching on Feebay and I've dicovered that extended rear brake lines are available in stainless for those sportbikes with freakishly extended swingarms, there are several lengths available in the $30-50 range, I'll be using one for my front brake when my bike finally goes back together again.
