Author Topic: shift points on a stock CB750  (Read 3518 times)
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« on: May 07, 2008, 06:41:04 PM »
What's the max MPH you can go in each gear at WOT to redline on your 750?
for me,
 1st to 2nd 45 50mph? (looking at the tach more then the speedo at this point  ;D)
 2nd to 3rd 65 70mph
 3rd to 4th ???
 4th to 5th  ??? ( I,ve only done the ton once) ::)
What is also the 0-60 time?
Not to open a can of worms but from what I herd stock CB750 1/4 miles are anywhere from high 13s to mid 12s?
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Gordon
  • 750K1, 550K2
Re: shift points on a stock CB750
« Reply #1 on: May 07, 2008, 06:45:19 PM »
Never really paid much attention to the speedo when accelerating that quickly.  In 5th gear I hit redline right around 100.
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #2 on: May 07, 2008, 07:03:26 PM »
Not sure about all the shift points, but with my stock(as far as I know -I haven't been into sprocketland) '77 750K I was at 100mph 4th gear 7k rpm, and 100mph in 5th gear 6,100 rpm if that's any help.
1977 CB750
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: May 07, 2008, 07:05:19 PM »
I should amend that by saying I have good reason to believe neither the speedo or tach are all that accurate. ;)
« Reply #4 on: May 07, 2008, 07:24:44 PM »
It's that or your gearing has been altered gordon.
Sam. ;)
Offline Kevin D
  • SE Michigan
« Reply #5 on: May 07, 2008, 07:26:27 PM »
Looks like Cycle World got 47, 68, 87, 106, 123. 13.38 1/4 mile out of a '69
http://www.sohc4.net/index.php?title=Image:69cwi7.jpg
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #6 on: May 07, 2008, 07:41:02 PM »
70, 93, in 7.4 seconds, 104, 117 in 12.03 seconds....not sure after that but there's no more gear changes anyway ::) ::) ::)....will let you know on Monday what the top end is ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
« Last Edit: May 07, 2008, 07:44:24 PM by SamCR750 »
« Reply #7 on: May 07, 2008, 07:41:39 PM »
Yeah, Jim Chamberlain and I didn't believe that article, so we took his Vetter Phantom fairing equipped CB750K0 to the 1/4 mile strip in Peoria. He went 12.99, 101+ MPH, fairing and all...the Phantom was the forerunner of the more popular 3-piece Vetter and lowers. His gearing was the then-stock 16/45T combo, ran D7E plugs for the tests. He had over 20,000 miles on it, then, too.
« Reply #8 on: May 07, 2008, 07:47:42 PM »
Proving that the early model was the one to have Mark. ;)
Sam. ;)
« Reply #9 on: May 07, 2008, 08:17:59 PM »
So.. the early one with a FAIRING, should kick the late ones butt, even without a fairing... ;D
Man you gotta love that...
If you have a fairly  hot cam, you can add 25% to all those speeds with stock gearing.. :o..
....like my bike..
« Last Edit: May 07, 2008, 08:25:47 PM by 754 »
Offline dustyc
  • 1977 CB750K
« Reply #10 on: May 07, 2008, 08:21:16 PM »
1977 CB750
Offline cb350twin
« Reply #11 on: May 07, 2008, 08:35:16 PM »
Ya, was gonna say that totally didn't sound right.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
« Reply #12 on: May 08, 2008, 06:36:27 PM »
Sam. ;)
Boy, you got THAT right! It took me 4 years to get 67 HP out of my K2, his put it on the ground from day 1. He NEVER let me forget that!  :D
Offline 333
  • Time for change
« Reply #13 on: May 08, 2008, 07:04:29 PM »
  Why would you think that?  If the cables are good, at least one (speedo or tach) should be at least close.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Mantree
« Reply #14 on: August 30, 2015, 02:59:02 PM »
I have only hit the ton 1 time on my 750 and I was at red line in 5th at about 105 i am geared a little under stock with the 16" rear wheel and I have a hot cam as for time to 60 I haven't timed it but that day I was at 90 by the end of the merging lane southbound i25 at the mulberry exit coming out of fortcollins
Sent from my SM-G900V using Tapatalk
Offline Desert-SOHC
  • It's old
« Reply #15 on: August 30, 2015, 06:21:07 PM »
Havent really looked at the speedo till I'm in 5th, but I know doing redlines through the gears, while getting on the highway on my onramp......I hit 110 when I merge and am in 5th at a bit over 7,000 rpms.  I would say this is the norm for my 78 K8 since I can do it every time.  For a 37 year old bike, its still pretty impressive how "spritely" it is for its size.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
