Author Topic: 520 CHAIN CONVERSION  (Read 1782 times)
JASONA317
« on: May 08, 2008, 08:27:18 AM »
 I HAVE JUST PURCHASED A 73 CB 500 FOUR AND AM NEW TO THE FORUM HAS ANYBODY TRIED TO CONVERT A CB 500 OVER TO A 520 CHAIN SIZE?
Re: 520 CHAIN CONVERSION
« Reply #1 on: May 08, 2008, 09:10:05 AM »
Yes, I switched to a 520 o-ring chain. Bought an anodized aluminum rear from Sprocket Specialists and machined a new front to fit.
JASONA317
« Reply #2 on: May 08, 2008, 10:12:57 AM »
 DID SPROCKET SPECIALIST HAVE THAT OR DID THEY MAKE IT UP FOR YOU AND WHAT FRONT DID YOU USE?
« Reply #3 on: May 08, 2008, 10:28:49 AM »
They will make both sprockets for you.
JASONA317
« Reply #4 on: May 08, 2008, 11:08:33 AM »
THANKS FOR THE INFO I WILL GIVE THEM A CALL
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: May 08, 2008, 12:01:53 PM »
GOOD LUCK AND turn off the caps lock.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #6 on: June 16, 2008, 10:50:44 AM »
to wake up an old thread here, has anyone besides bwaller made this conversion? i ask specifically because the front is what i'm concerned about, and brent's wasn't from sprocket specialists.
my SS front has no retaining holes, and came only with a clip that replaces the stock retaining plate. there is no spacer for either side, which would allow the sprocket to float on the shaft. i talked to the guy that makes all of their sprockets (randy at advanced precisions) and he says he's seen thousands if not a million of them go out like that, and has never heard of one hitting a case. he says the chain itself will keep in in alignment. i can't help but feel a little nervous about this.
has anyone run one like this? should i machine spacers to locate it and secure it properly?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline TomC
« Reply #7 on: June 18, 2008, 06:40:14 AM »
Hi Paulages
     I am currently running a 520 X-ring chain on my CB400F1. I am just using the C-clip with the front sprocket. I looked in there to check and saw no problem.
     When I do this with my 550 I will keep an eye on were the front sprocket is running. I am thinking that rear wheel alinement will control were the front sprocket runs. Also on my CB400F1 the rear sprocket goes on one way. The cut to reduce the width for the 520 chain was made on the outside. If the CB550 rear sprocket only mounts one way I would have the cut made on the inside of the rear sprocket. That way the centerline of the chain would be moved out away from the engine case.
          TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline paulages
  • 1976 cb735
« Reply #8 on: June 18, 2008, 11:25:49 AM »
Hi Paulages
          TomC in Ohio
thanks, tom. good info. not much i can do until i get the engine finished and mounted, but it's good to hear some feedback from someone running the same setup.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
