Author Topic: Adjusting the neutral switch??  (Read 782 times)
Mattydiah
« on: May 08, 2008, 08:56:11 AM »
On my 77 750K, the neutral light works, and is on when I'm in neutral.  When I put the bike into gear, it doesnt go out, it just sort of gets dimmer.
Is there a way to adjust this at all?
Offline mystic_1
  • 1970 CB750K
Re: Adjusting the neutral switch??
« Reply #1 on: May 08, 2008, 09:22:39 AM »
There's no adjustment.  The switch can, in theory, be disassembled and cleaned, but if it's bad you're better off looking for a replacement.
Just to be sure of things, check for a short to ground in the wiring.  The switch operates by connecting to ground when you're in neutral, so if you have a chafed wire somewhere, that'll keep the light from going out.
mystic_1
- John Augustus Shedd
