Author Topic: Drive Sprocket  (Read 660 times)
Offline 77honda
Drive Sprocket
« on: May 09, 2008, 01:43:31 AM »
I am rebuilding a 1978 K7 and have notice that the 15t drive sprocket is a "loose" fit on the splined shaft. It wobbles both forward and back and also sideways to a small degree, is this normal or is the sprocket worn.
Thanks, Mike
CB750 K7
Offline Johnie
Re: Drive Sprocket
« Reply #1 on: May 11, 2008, 06:07:54 AM »
You may want to do a search of the archives.  I seem to recall this coming up before.  I think some play is normal there.  Some play, not accessive play.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Bob Wessner
  • "Carbs Suck!"
Re: Drive Sprocket
« Reply #2 on: May 11, 2008, 06:48:31 AM »
This is normal. It allows the sprocket to "follow" chain movement to a degree.
