Author Topic: Intake tube stretcher  (Read 6551 times)
Offline Kevin D
  • SE Michigan
« on: May 09, 2008, 02:34:29 PM »
The carbs went on easy, my OE carb insulators have held up pretty well. But I was having a heck of a time with the airbox. The intake tubes are as hard as a rock. I've been keeping them oiled in hopes of softening them, but it didn't help nearly enough.
A golf ball is 0.100" bigger than the carb opening. I shoved 'em in and gave it 5 minutes at 200f, then shoved 'em in some more and another 5 minutes in the oven. The golf balls kept it warm until I got outside. The airbox went on as easy as pie.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Intake tube stretcher
« Reply #1 on: May 09, 2008, 03:12:08 PM »
Very innovative. Thanks for that tip.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: May 09, 2008, 04:33:11 PM »
Great use of golf balls. I never seem to be successful with their intended use. :-\
Offline Kevin D
  • SE Michigan
« Reply #3 on: May 09, 2008, 07:54:05 PM »
Maybe you recognize one of them Bob, because they've all been lost - and found - at Leslie Park. :D
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: May 10, 2008, 04:59:54 AM »
 ;D ;D
Actually, I finally gave up on golf. My performance never even came close to my expectations. :D
« Last Edit: May 10, 2008, 05:02:57 AM by Bob Wessner »
Offline mustangcar
« Reply #5 on: August 06, 2008, 03:16:08 PM »
had a hard time putting on the air box on my k8 today, noticed they only lined up if the little slash  that looks like this - its molded on each rubber boot is on top up 12:00 oclock on each boot,,then they lay nice and flat,they also had a flat cut on the rubber boots they face on the bottom at 6:00 oclock,,maybe only the k8s are like this? and maybe its been posted before oh well wish i would of known this ,had me quite sweaty for a bit :-\
« Last Edit: August 06, 2008, 03:34:41 PM by mustangcar »
troppo
« Reply #6 on: August 07, 2008, 02:29:32 AM »
Great tip mate, finally a use for golf balls that doesnt involve that ridiculous game :D ;D
racer69
« Reply #7 on: September 23, 2008, 07:42:34 PM »
I have race cars and had some tire softener sitting around and soaked some boots. After a day they still were hard as rocks. Then i realized the tires don't work until you get some heat in them. So I use a heat gun(wife's blow drier) and they was as pliable as new. since then, I have developed my own softener . but basically its just laquer thinner and trans fluid. hope this helps!
