Author Topic: CB550 Tach drive ratio?  (Read 2206 times)
Offline freezingprocess
  • Chris
    • My '76 CB550 Project Gallery Site
« on: May 09, 2008, 04:41:35 PM »
Does anybody know what the tach drive ratio is for a 1976 CB550? I've looked all over the forum, but haven't found a definitive answer. I've gotten either 7:1 or 4:1.  :)
-Chris-
'76 CB550k
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: CB550 Tach drive ratio?
« Reply #1 on: May 09, 2008, 05:02:17 PM »
Chris
I'll count the gear teeth later tonite and post the findings if you don't get a answer from someone else first.
FJ
« Reply #2 on: May 09, 2008, 05:58:16 PM »
I read this here just a while back. 350/400/500/550's are 20:3.  750's are 4:1
  • Chris
« Reply #3 on: May 09, 2008, 06:10:32 PM »
Chris
FJ
Ha ha- I should have been smart enough to figure that one out. I'm going to try counting them when I get home too. Thanks FJ
'76 CB550k
  • Chris
« Reply #4 on: May 09, 2008, 06:11:47 PM »
Thanks Bwaller-
'76 CB550k
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #5 on: May 09, 2008, 06:17:54 PM »
Brent
I found that info too.
That ratio of 20:3 must be the tach's internal ratio.
« Last Edit: August 26, 2010, 12:02:00 PM by FunJimmy »
« Reply #6 on: May 09, 2008, 07:13:09 PM »
Yea Jimmy, you're right.
Offline bruisedlee
« Reply #7 on: August 26, 2010, 10:52:39 AM »
sorry to bump old thread, but what tach ratio for cb650?
Offline bruisedlee
« Reply #8 on: August 26, 2010, 11:18:45 AM »
will these electronic tachs work? http://cgi.ebay.com/ebaymotors/Custom-Mini-Electronic-Tachometer-Gauge-Harley-_W0QQcmdZViewItemQQitemZ140422147441QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_1151wt_679
this is exactly what i'm looking for but it is listed for a harley.  i think it hooks up to the coils?
this might help to see if its compatible: http://www.speedwayinstruments.com/uploads/microTach_instructions_tachadapter.pdf
Offline Laminar
  • Retsam
« Reply #9 on: August 26, 2010, 11:30:34 AM »
As far as I can tell, you need an electronic ignition if you want to run an electronic tach. I tried a few different electronic tachs with my stock ignition-ed 550 and nothing worked correctly.
Offline bruisedlee
« Reply #10 on: August 26, 2010, 11:50:56 AM »
my 550 has dyna s or is that not gonna work either?
Offline Laminar
  • Retsam
« Reply #11 on: August 26, 2010, 12:01:15 PM »
That's fine, just about any electronic Honda tach from a bike with waste spark will work for you, as will many others.
Offline bruisedlee
« Reply #12 on: August 26, 2010, 02:15:04 PM »
sorry don't quite understand what you are saying.
so with my cb550 with dyna s ignition and coils, i should be able to run these: http://cgi.ebay.com/ebaymotors/Custom-Mini-Electronic-Tachometer-Gauge-Harley-_W0QQcmdZViewItemQQitemZ140422147441QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_1151wt_679
Offline Laminar
  • Retsam
« Reply #13 on: August 26, 2010, 02:19:20 PM »
Do a search for "electronic tach" and you'll find plenty of answers.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #14 on: August 26, 2010, 06:23:13 PM »
Those Harley tachs have too low of an RPM range to be suitable on our bikes.
I used a '82 VFR750 electronic tach with my Dyna set up and it's perfect.
