Author Topic: My long-overdue Spark Advancer post...  (Read 18607 times)
Re: My long-overdue Spark Advancer post...
« Reply #25 on: December 15, 2014, 06:44:26 PM »
I'm not sure if it's 40 degrees but it's definitely the same as the three later sandcast ones.  I put one of the later ones on the crank and lined up the 1-4 T mark with the mark on the cases.  Then after I cleaned up just enough to see the same marks on the E100 advancer l put it on the crank and the T mark lined up exactly.
The T mark is for Top Dead Center, so it should always be the same. Set the mark for the full advance marks, then see if 100 matches.
Offline kmb69
« Reply #26 on: December 15, 2014, 06:47:02 PM »
Mark, I think you need to check the angle between the 'T' and the total advance marks to really answer the question. The 'T' marks, TDC, should line up no matter what version. It is the total degrees of timing advance that may determine the version.
Sorry Scottly, I was typing while you were posting.
« Last Edit: December 15, 2014, 06:48:52 PM by kmb69 »
Offline 01Thomas
« Reply #27 on: December 16, 2014, 01:59:30 AM »
"Ping" - just to bookmark this thread.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline markb
  • When I finish my current project I might be a
« Reply #28 on: December 16, 2014, 06:11:54 AM »
Makes sense.  I will do some more investigating.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline markb
« Reply #29 on: December 18, 2014, 06:18:17 PM »
I soaked the advancer in Safest Rust Remover and I was able to clean it up enough to read the markings.  Besides the timing marks there is a TEC logo on one side…
….and a 300 with an arrow on the other side.
So it’s definitely not a 450 advancer.  I looked in parts manuals and this shape with the slots shows up in the 1975 and later K and F models.  I also looked in early parts manuals and shop manuals and they have the same shape as my later sandcast ones.  I don’t think mine is original.  Any other opinions?
Offline kmb69
« Reply #30 on: December 18, 2014, 07:56:49 PM »
Yep, the early advancers are Hitachi.
« Reply #31 on: December 18, 2014, 09:28:49 PM »
The "slotted" ones you see in the parts fiche are the -323- series advancers (most made by TEC). They are a larger round-ish baseplate than these, too. The -323- have a different static timing and advance angle (and rate) from the early engines, being made to operate with late-opening intake cams (0 BTC).
The "300" definitely puts them into the pre-1975 engine. The advancers were made by 3 companies at different times, mixed back and forth between New Factory and Old Factory, with the bulk of pre-1972 versions made by Hitachi. This logo looks like 2 concentric circles with a sort of "H" in their midst. The TEC is distinct, and the ND shows up, usually in K1 bikes, pretty often.
The curious part here (to me) is the slots behind the springs. This makes it look like it started out as a 450 twin advancer plate, which may be how it came to be? Those were largely TEC-made. The sandcasts sported many parts that came from the Big Twin. If the bolster in the center were then changed to fit the 750 shaft, that might be their origin?
Cool stuff!
Offline kmb69
« Reply #32 on: December 18, 2014, 10:08:55 PM »
Anybody got a picture of a ND for a 750? Don't recall ever seeing one.
« Reply #33 on: December 19, 2014, 04:46:41 PM »
The advance from my K7 parts motor is a TEC, marked 300.
My K1 looks like it has the Hitachi logo, and is marked AD125-01.
« Reply #34 on: December 19, 2014, 07:08:18 PM »
Checked my 2 loose ones. My original 75 CB750F is a TEC as is my 78 CB750K. Couldn't get to the other on my spare 75 CB750F engine though so thats no help Keith.
Bill Benton has a #$%*load of spares. Maybe he can take a look Keith?
« Reply #35 on: December 19, 2014, 08:13:18 PM »
When you see one: the "T" and "F" marks are tiny, and are inside the arc of their timing marks. They were hard to see in a timing situation.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #36 on: December 20, 2014, 08:01:13 PM »
Some pics, 323 are 500/550, 300 are CB750, 333, 350/400F and then some others early ones etc. Bill Have fun! Haha.
BentON Racing Website
BentON Racing Facebook
« Reply #37 on: December 22, 2014, 09:13:25 PM »
Hey, Bill, I can't quite tell: in your collection, do you have both the -323- with the "thick" wire springs and the one with the "thin" wire springs? It was said the "thick" ones were for the 500/550K, the "thin" ones for the "F" bikes. In practice, I couldn't confirm that, though?
Trivia, trivia... :(
« Reply #38 on: December 23, 2014, 10:56:41 AM »
Mark,
Have you seen that Yamiya has new springs? Can't tell you anything about them though. I may be placing an order with them soon and could add some to it for you if interested.
Offline markb
« Reply #39 on: December 23, 2014, 12:14:33 PM »
I didn't see that before but I checked it out.  Did you see what else they had?
http://www.yamiya750.com/index.php?main_page=product_info&cPath=21_55&products_id=2935
 :o ;D
Thanks for the offer on the order.  I'm actually making a list myself that I will be ordering soon.
« Reply #40 on: December 23, 2014, 05:11:21 PM »
We have Marks everywhere  ;D You AND Hondaman. Anyone else needs anything minor Markb and I would gladly add to our orders.
That NOS advancer looks nice. It's a 300. But, for ~$300.00 I think I'd just get new springs  ;)
Their site is kinda tricky. I've found it's best to click through on each part if you really want to see the whole picture.
« Reply #41 on: December 23, 2014, 05:38:52 PM »
Hey Jerry, add a pair of springs to your order for me, please.  8)
« Reply #42 on: December 23, 2014, 07:16:30 PM »
Will do, not sure how quick I'll send it in. Next week or 2 MAYBE. I have numerous orders to do for the 1000 engine but still need to tear into the existing 900 A G A I N........but later.
ServiceHonda (seals, o-rings, gaskets, primaries). APE (top and bottom studs). Dynoman (RC315). Yamiya. Amazon (Tsubaki). KenoshaKid (swing arm bushings & bolt set). Then there's CB750Supply, CycleX, PartsNMore, ETC.
Do I go with Honda gaskets and seals or aftermarket?! Complete kit and have leftovers, etc?!
ETC ETC ETC  $$$$$$$$
« Reply #43 on: December 23, 2014, 07:32:52 PM »
Hey Bro, I'm not in a hurry at all. I just want them in case I need them, and then, if ordered separately, the shipping would exceed the cost of the part. ;)
« Reply #44 on: December 23, 2014, 10:11:18 PM »
Shipping, exactly. That's why I'm offering to add stuff to my order. I'll include them. May pull the trigger this week. I'll let you know. Only want to do one order due to that shipping monster. Trying to decide if I want to chance bearing sizes for the crank. $8.77 each and $6.24 for the rods. Going to use the Crowers on the 1000. Not sure about sizing and my pre-measuring skills and equipment leave a little to be desired. May order green and hope for the best. I can always farm them out.
Anyway, back to the advancer and spring thing. Anyone else want new springs or whatever from Yamiya?
« Reply #45 on: December 24, 2014, 12:48:32 AM »
Finally! Order advancer springs is possible!
HONDA CB750 RACING GOVERNOR SPRING   (I did not see any link to these in earlier posts)
http://www.yamiya750.com/index.php?main_page=product_info&cPath=21_55&products_id=2168
I have to find other parts to order too when the shipping cost is way too much for the 2 small springs only
« Reply #46 on: December 24, 2014, 11:46:36 AM »
PeWe,
I have a feeling that those 2 inexpensive springs are going to cost you a bunch. May as well fill up a box which is what I'm going to do WITHOUT the springs unless someone here in the States wants me to add some to my order also for them.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #47 on: December 24, 2014, 12:25:13 PM »
Jerry,
Will those springs work for my 1976 K6????
I still have the original springs in mine, but will be going through the engine soon to get it running again.
If they will work, I'd be interested.
Charlie
Offline edwardmorris
  • Youngish
« Reply #48 on: December 24, 2014, 12:40:18 PM »
IIRC I read somewhere that springs and weights on these are interchangeable, so they may work. I ordered a set a while back via JT but haven't installed them.
« Reply #49 on: December 24, 2014, 03:29:59 PM »
PeWe,
Hey, Jerry: I am about to finish up a K5 that the owner would like the 4-4 pipes from Yamiya (maybe). I'll ask: if so, I'll contact you about it and maybe we can do something about the shipping?
