Author Topic: Batteries 12N14-A2 vs 12N14-A3 What is the difference?  (Read 3303 times)
Offline dboblet
  • OMG - what did I get myself into this time!!??!!
« on: May 11, 2008, 09:07:20 AM »
boing for the *last* item I need before I put all the parts back togeather.  But, searching on line I see these two batteries, one an A2 and one an A3.  The dimessions look the same.  So, what is the difference?
I see I can get a fair price for one with acid and reasonable shipping on E-bay.  I'm not sure if I can get one locally, being in the mountians as it were.  oh, '78 CB750F if it makes any difference.
Thanks.
No matter where you go, there you are.
Re: Batteries 12N14-A2 vs 12N14-A3 What is the difference?
« Reply #1 on: May 11, 2008, 09:13:03 AM »
I doubt they could ship it with acid in it at least by some carriers.
Could be as minor as post location, overflow tube location. Not a problem to some , but not worth messing with your harness if you want to stay stock IMO..
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #2 on: May 11, 2008, 10:23:22 AM »
http://www.yuasabatteries.com/pdfs/2008yuaapp.pdf you could try this, part way down it shows how the coding works, you may have the last letter/numbers the wrong way around.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #3 on: May 11, 2008, 10:41:12 AM »
I **think** the A2/A3 thing has to do with the terminal post polarity.
The microfiche shows 12N14-3A
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: May 11, 2008, 10:43:34 AM »
12N14-3A:   side post battery   (conventional)
YB14L-A2:    top post battery   (Micron)
YTX14AHL-BS:  top post battery     (no maintenance, high performance)
   Get either of the "top post" batteries.  They will ship dry and you will need to activate them. You need a 1.5-2 amp charger to juice them before using.
