Author Topic: carb/dyna ignition install questions questions  (Read 1058 times)
Offline zoo mob
« on: May 13, 2008, 11:58:26 AM »
I'm about to install dyna coils and ignition into my 73 750 k3 and am wondering what I need to do, if there is a tutorial somewhere etc. Also, I'm in the process of rebuilding my carbs, do I need to worry about the bracket for the choke, does that need to be precisely adjusted to work properly? Lastly, when doing the rebuilds does anyone offer just the gaskets? It looks like the kits I've seen come with stock jets, and I think I need to downsize, mine are 120's and it seems to run a bit rich, airbox is drilled, and have a mac 4-1. Sorry for so many questions in one post, and thanks.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline mystic_1
  • 1970 CB750K
Re: carb/dyna ignition install questions questions
« Reply #1 on: May 14, 2008, 06:05:33 AM »
What makes you think you're running rich?  With a drilled airbox you're probably running lean, if anything.
mystic_1
- John Augustus Shedd
Offline zoo mob
« Reply #2 on: May 14, 2008, 10:16:26 AM »
Carbon fouling on the plugs.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
