Author Topic: Wheel Bearings?  (Read 1112 times)
Offline cjbear11
Wheel Bearings?
« on: May 17, 2008, 12:49:57 AM »
I need new wheel bearing on my front wheel.  What are the best to use, and where can i get them?  My bike is an '83 CB650SC Nighthawk.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Wheel Bearings?
« Reply #1 on: May 17, 2008, 01:04:38 AM »
Check the manual to see if it is a 'special' size that you can only get from Honda. Better still take the original to your local bearing emporium and they will tell you whether it is one that they can replace or one that you have to order OEM. The factory will always charge more for a replacement bearing that you could have got from a generic supplier.
Nick J. Member #3247
2010 Thruxton 1979 XT500 1971 Commando 1969/71 Honda Z50A
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
Re: Wheel Bearings?
« Reply #2 on: May 19, 2008, 06:03:12 AM »
Do the wheel bearings get cleaned and greased when the tires are replaced?  Or should they be?  Is it automatic for a good shop to do that?  thanks
Enjoying life, one day at a time.
Offline Johnie
Re: Wheel Bearings?
« Reply #3 on: May 19, 2008, 07:48:22 AM »
No, it is not automatic for the shop to clean & repack wheel bearings.  Most of the bearings are pre-packed and factory sealed and you can not take them apart.  You can not add more grease.  Even my 1970 had sealed bearings.  1 of the bearings on the front of my KO was loose and I could tell it was dry.  So I just replaced them both.  Then I figured I may as well do the 3 in back too.  Now I know what I am driving on have that piece of mind.
John
1970 CB750K0 - Candy Ruby Red
1970 CB750K1 - Candy Gold
1973 CB750K3 - Candy Bacchus Olive
1974 CB750K4 - Flake Sunrise Orange
2000 1500 SE Wing
Honda's owned in the past:
1965 65SS, 1969 CB350, 1971 CB350, 1972 CL175, 1974 CB450, 1975 CB360T, 1977 CB750K, 1980 CM400E, 1981 CM400C
Oshkosh, WI  USA
    • bloggy thoughts
Re: Wheel Bearings?
« Reply #4 on: May 19, 2008, 09:12:13 AM »
Yeah peace of mind is good to have.  I didn't think about the bearings being sealed.  Makes sense, though.   thanks
Honda
