Author Topic: Squirley's 550 CAFE Build  (Read 162103 times)
retro
Re: Squirley's 550 CAFE Build
« Reply #150 on: February 16, 2009, 10:10:59 AM »
This thread has been very motivational to me as I have just picked up a cb360 and am very anxious to start the build.  Want to get the mechanical all sorted before I start on frame and body mods, but thanks for the inspiration.
Cheers.
Offline squirley
« Reply #151 on: February 17, 2009, 12:02:28 PM »
Retro, I am glad it is an inspiration to some, thanks for the kind words.
StrongPerf, for some reason I don't think your 550 will get much lovin now...new toys always get priority.  Be safe on those things, I rode a zx6 once and that was a quick bike, I can only imagine how fast it's daddy is.
Hey Fuzzy, i just read back through the posts and saw your post there.  If you still have the petcock, I do need one.  Let me know how much you want for it and I will give you an answer.
thanks again all.
Jens
Offline Stevevo8
« Reply #152 on: February 17, 2009, 05:40:06 PM »
This may be a really dumb question, but where would I go buy shims to install for the top bearing on the forks?  I'm guessing like a machine shop or something like that, but I could be completely wrong. Thanks for the help!
You no longer need to. All Ball Racing has provided some very helpful assistance in combining two bearings to fit our old CB’s.
Here are the part numbers:
99-3506/33-1006 (30-48-15)
99-3511/33-1006 (26-48.5-15)
The bearing section from the 99-3506 is used with the race of 99-3511 achieving an assembly of (30-48.5-15).
This is the current bearing setup that I’m using and the fit is perfect.
You end up with a 48.5mm race that fits the head tube and a 30mm ID that fits the modern steer tube.
Picture of this assembly in my 550
Call them directly at:
All Balls Better Bearings & Components
PO Box 437, 822 N Reading Ave
New Berlinville, PA 19545
Tel: 888-228-3323, 610-473-0505
Nice Work Squirely,
Do you guys know if the sizes on the 400f are the same as the 550???
Offline raymond182
  • 1971 CB500, 1972 CB500, 1978 KZ1000, '76 CB550, 1999 ZRX1100
« Reply #153 on: February 21, 2009, 11:13:12 AM »
Squirely,
Help me out here man, I have the narrow glide hub (just like yours) but can not source the rim. What did you use, regular Sporster aluminum rim?
Thanks.
Res Ipsa Loquitur, but what does it say?
Offline squirley
« Reply #154 on: February 21, 2009, 11:26:47 PM »
Sorry stevevo8, I have no idea what parts make up a 400, I am sure someone may chime in and answer if you ask around
Raymond, I used an aluminum did rim off ebay.  It was you basic replacment wheel for a harley (19x2.5" with 40 spokes).  I am sure you could also use just the stock steel harly rim that comes on a narrow glide if you wanted to. I will try to find a similar rim to the one I used on ebay and post a link.  There was a guy selling a lot of of DID aluminum rims for 60 bucks each brand new, I will let you know if he still has any.
Hope this helps
Offline fastbroshi
  • Puppet
« Reply #155 on: February 22, 2009, 09:37:43 AM »
Nice Work Squirely,
Stevevo8, yes they match. Go here:
http://www.ohiocaferacers.com/OCRStemSizes.pdf
Do a Ctrl + F and search for cb400.
Just call me Timmaaaaay!!!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #156 on: February 22, 2009, 09:40:29 AM »
Steve
The CB400 uses the same All Balls RAcing bearing set as the 550 so the bearing combination listed above would allow you to use a modern forkset with 30mm stear tube. What I don't know for sure is the steer tube length. That you would have to measure and then confirm it with the forks you are considering using.
FJ
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #157 on: February 23, 2009, 03:34:32 PM »
Hey squirley, do you remember what the part numbers were for thosse shock rebuild kits? I've got a pair that need done for a buddys bike...a 81 cb900f.....also what was the cost for each kit.  thanks.
MATT
Offline squirley
« Reply #158 on: February 23, 2009, 09:41:09 PM »
Sorry Kronus, most of my parts were purchased through ebay, so I don't have any sort of part numbers or info on where to find such stuff.
On another note, just a quick picture of the beginings of a frenched in tail light.  Now if I can just bend a piece of smoked plexiglass to fit the curve, I might be happy.
Offline BlindJoe
« Reply #159 on: February 23, 2009, 11:14:14 PM »
Its really starting to come together, that thing is gonna look sick!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #160 on: February 24, 2009, 01:51:47 AM »
Gonna! It already does.
Where did you get the tail light?
That could be the answer to me tail light issue too.
Cheers
FJ
Offline squirley
« Reply #161 on: February 24, 2009, 07:45:08 AM »
Thanks guys.   The taillight is a flexible led strip that I picked up off ebay.  If you search under 12volt flexible led you will find several.
I made a little resistor pack so it will operate as a tail light and a brake light.  If you don't want to make one, you can also find them on ebay. (http://s291.photobucket.com/albums/ll312/gaolbird/?action=view&current=48cmDualCircutvidAmber.flv)
Two flexible LED strips:  $10.00
Making a dual circuit resistor pack:  $1.00
Smoked plexiglass sheet:  $5.00
___________________________
TOTAL:  A reminder of how much I don't like fiberglass.
Offline Stevevo8
« Reply #162 on: February 24, 2009, 09:02:14 AM »
Check out http://www.alumilite.com/HowTos/TailLightMoldingNoEquipment.cfm
You can use their products to make almost any  shape of palstic you need.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #163 on: February 24, 2009, 09:37:48 AM »
Wow! That's a lot brighter than I thought it would be.
Add another item to the already over flowing job jar.
Thanks Jens!
Cheers
FJ
Offline jeepurz
« Reply #164 on: March 01, 2009, 11:17:02 AM »
wow! thats cool, do you or could you post the wiring diag for that dual circut ?  I made a copper tail for my 550 project and im lost on the taillight.
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #165 on: March 01, 2009, 04:18:59 PM »
i would like to know the dual circuit trick as well
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline squirley
« Reply #166 on: March 03, 2009, 10:59:06 AM »
I would be happy to show how to make up a dual circuit converter.  I will try and make time to do a write up this weekend.
On another note.  As I have gained so much from this forum, I would like to give back.  I have some leftover parts that I would like to get rid of from the stock 550.  All parts are FREE (unless you feel like contributing a 6 pac or the like), and there are some good things left.  Unfortunatley, I do not want to ship, so local pickup is ideal.  Parts include but not limited to:
Pegs ( i think front and rear)
Frontend--forks, handle bars, brake, etc.
front and rear rims ( come with nasty tires)
Rear akront aluminum rim with 550 hub
Airbox and plenum
guages
exhaust down tubes.
Yada yada yada
Please, if anyone is clost to santa barbara, please come get this stuff.  Craigslist is next....
Offline BlindJoe
« Reply #167 on: March 03, 2009, 02:32:05 PM »
more details on the akront rim please? would you be willing to ship?
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #168 on: March 03, 2009, 02:54:03 PM »
That tail light is awesome.  Some act as a stop signal and turn signals, all in the same strip.  (Maybe that's what you got... not sure.)  See pic...
Link to where one can buy them:
http://www.customdynamics.com/flex_led_array.htm
A heads up though... I don't think they are entirely legal to use as stand-alone signals.  I think they're only supposed to complement existing signals.  I don't mention this to discourage anyone - only to let you know so you don't go showing off while riding in front of a cop.  :)
But these are the perfect lights for a cafe.
« Last Edit: March 03, 2009, 02:55:55 PM by soichiro »
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
« Reply #169 on: March 03, 2009, 04:47:18 PM »
Soichiro,
Why do you think the led combination lights are not legal as standalone signals?
  • Tuck
« Reply #170 on: March 03, 2009, 04:49:01 PM »
Soichiro,
I thought I read it somewhere.  Maybe it was on the website.  I could be wrong....
1974 CB 750
1966 Black Bomber
Offline syth82
  • 1976 cb550f project
« Reply #171 on: March 03, 2009, 04:56:38 PM »
Soichiro,
Pretty sure the short answer is brake lights, turn signals and tail lights are required by the DOT. If you replaced yours with a part that doesn't have a DOT stamp, it's technically not street legal.
-Luke
Offline squirley
« Reply #172 on: March 03, 2009, 09:12:33 PM »
Ya, the led that I am using is not one with built in turn signals, it is just a regular led that I am regulating power to in order to make work as both brake and running light.
I have had several pm's regarding the 550 parts give away... before I answer all questions, I will take some pictures of the items I have so you can decide if they are worth your time to come get them.  (I don't want dissapointments even if they are free).  I will post pics asap.
Jens
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #173 on: March 04, 2009, 04:22:51 AM »
legal shmeagle.... I run antique plates
Offline j-conn
  • Federico Fabrizi
« Reply #174 on: March 04, 2009, 06:00:25 AM »
i want to see more!
1976 CB550
Member #7772
