Author Topic: manifold bolts?  (Read 690 times)
Offline KeithB
manifold bolts?
« on: May 18, 2008, 04:52:10 AM »
I am replacing the nuts on the manifold studs and was wondering about using brass.
Brass "manifold bolts" are available from Canadian Tire ($1.40 ea).
They are the self locking type.
Any advantage to using them over standard hardware?
Nanahan Man
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: manifold bolts?
« Reply #1 on: May 18, 2008, 11:35:32 AM »
They should work fine, as long as they are not the "Nyloc" style with the plastic locker.
Brass ones won't seize on and are probably worth the cost.
I know from working on aircraft that they always use brass nuts on the exhaust, they look alot like "nyloc" nuts but the locker on the end of the nut is also made of brass.
 Cheers, Matt.
Gallery at:
Offline KeithB
Re: manifold bolts?
« Reply #2 on: May 19, 2008, 04:11:00 AM »
Thanks Matt.
The "no rusting" part is worth the money!
Nanahan Man
