Author Topic: Turn signals stop functioning, buzzer buzzes continiously, WTF ?  (Read 1290 times)
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
Hi all,
Yesterday after a ride, I have noticed that all  turn signal stopped blinking and the buzzer gives a continuous tone when the switch is engaged either left or right.
Any quick remedy or just the old "follow the wires" route?
TNX all.
Jona
Found real friends here !!!
Offline Klark Kent
Re: Turn signals stop functioning, buzzer buzzes continiously, WTF ?
« Reply #1 on: May 18, 2008, 12:34:19 PM »
swap out the realy before you go chasing wires.  get an electronic flasher relay.
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline cb750k7
« Reply #2 on: May 18, 2008, 12:54:18 PM »
TNX Klark,
Is this unit a universal car unit or a special HONDA motorcycle unit?
Jona
Offline Klark Kent
« Reply #3 on: May 18, 2008, 12:58:06 PM »
one size fits all, your local auto parts store is the way to go.
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline cb750k7
« Reply #4 on: May 20, 2008, 04:49:21 AM »
Hi all,
I am a bit puzzled.  According the wiring diagram,  the flasher unit has 3 prongs.
I have checked my unit and it has only 2 prongs.
Checked all the bulbs,  seems that all filaments are well.
The rear left socket had some corrosion,  cleaned it but still got the continuous buzz without blinking.
The flasher gets 12V while the switch is turned on to either L or R.
Does it narrows it to the flasher unit?  And 2 or 3 prongs?
Tnx all
Jona
Offline Klark Kent
« Reply #5 on: May 20, 2008, 05:11:12 AM »
the third terminal is unneccessary.  if they are labeled P, L and X- P is for pilot and can be left alone.
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline cb750k7
« Reply #6 on: May 20, 2008, 05:15:16 AM »
Indeed they are marked X and L.
TNX KK
Offline seanxnj
  • St8Skrapen
    • Cityscapes
« Reply #7 on: May 28, 2008, 07:05:25 PM »
So did you ever figure out what happed with it cause mine is doing the same exact thing, and i don't wnana buy a new flasher relay if i don't have to
silentone
« Reply #8 on: May 28, 2008, 07:15:54 PM »
A new flasher is only around $5 (sometimes less).
« Reply #9 on: May 29, 2008, 05:12:42 AM »
Stock flasher units are thermal flashers whereas newer ones (for around $5) are electronic so no need for it to warm up or depend on the RPMs of the bike! Easy!
