Author Topic: blinkers  (Read 1130 times)
nashport_native
blinkers
« on: August 21, 2005, 06:53:42 PM »
anyone had the dash lights for the blinkers stay on all the time?
the only time either of them will go out is when I turn the blinker on, but they dont blink.
thanks for any ideas.
mike
Offline DammitDan
  • Prodigal Son
  • It lives!
Re: blinkers
« Reply #1 on: August 21, 2005, 07:26:28 PM »
Mine does the same thing... I think it's a wiring problem, although it may be a faulty relay or switch.  I've been looking over the wiring diagram but staring at it doesn't seem to help much ;)
CB750K4
Offline Steve F
Re: blinkers
« Reply #2 on: August 22, 2005, 01:58:24 AM »
Make sure you don't have the "dash" lights plugged into the wrong receptacle.  What you might have is the dash lights plugged into the wire that connects to the front running lights, which are (at least in the U.S.) on all the time except when you operate the turn signal, or when you hit the HIGH beam switch.
