Author Topic: foot pounds .. pounds foot  (Read 894 times)
Offline DJ_AX
« on: May 19, 2008, 05:51:31 AM »
Ok I know I'm not blind...  :-\ or maybe I am ... but for the life of me I can not find the torque values anywhere (particularly for the triple tree / fork clamp bolts... (12mm top, 14mm bottom) '75 cb750k5)
I've spent at well over an hour searching this forum, the faqs, the service manual, the clymers manual and google. .. I'd  expect it to be right up front all over the place and in my face but ..
I must be spelling it wrong or using the wrong words or something. ..
Offline Gordon
  • 750K1, 550K2
Re: foot pounds .. pounds foot
« Reply #1 on: May 19, 2008, 06:16:08 AM »
The Clymer manual calls for 13-17 Ft/lbs for both.
Offline DJ_AX
« Reply #2 on: May 19, 2008, 06:32:25 AM »
Thanks... I must look again ...
My wifes a jeweler ... she calls it bench blindness.. .when somethings right in front of you but you just can't see it.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: May 19, 2008, 07:03:29 AM »
It's in the "Quick Reference" section in the front of the manual, under Frame Torques.
I get that bench blindness all the time when I'm working in the garage.  I have the amazing ability to "lose" the socket wrench that I just had in my hand ten seconds ago. ::)
Offline Klark Kent
« Reply #4 on: May 19, 2008, 07:41:20 AM »
psst.  Gordon.  It's in your hand.
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline Raul CB750K1
« Reply #5 on: May 19, 2008, 07:43:05 AM »
I only use the torque specs for the head bolts or nuts. For the rest, I use my "inner" torque wrench. Everything tight but having into account the bolt and nut/thread material. If something is important to remain tight, use a spring nut or loctite instead of over-torqueing.
It is just a byproduct of my lazyness and to speed installation up. Never had any issue until now -knock on wood-
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: May 19, 2008, 07:43:16 AM »
Dude, that's creepy...
Quit watching me!!!!!!!!
Offline Klark Kent
« Reply #7 on: May 19, 2008, 07:44:41 AM »
 8)
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline DJ_AX
« Reply #8 on: May 19, 2008, 08:04:39 AM »
....I use my "inner" torque wrench. ......
Same here usually... but mine apparently needs to be calibrated.
