Well, after fixing my problems, I'm running into yet another one....
This one is going to be fun.... I got everything hooked up and set, and I go to restart her (gas tight and vacuum tight) and she'll kick over and idle for exactly
2 seconds......and then she dies.
She'll keep doing this with the choke fully closed and what's weird is, if I try to throttle her, she dies much faster than just leaving the throttle at neutral.
Pump is working cause I can hear it, and well, I can only reach the 2 otter carbs to see if there getting gas, because of the drain screws.
But I do smell gas in all 4 carbs.
I will be getting up tomorrow morning to install the gas tank instead of my shops testing gas tank. The tank I'm using is only half of a gallon, where as the VF's gas tank is like over 3 gallons.
I'm thinking the down force of the gas might be playing a huge part....
What is amount of gas the pump is suppose to pump per second??
And what could be the problem other than what I'm mentioned??
Thanks again for all the help. I hope to be driving my very first Interceptor....not that CB400F's stink
LL
