Author Topic: Lunchtime quickie.....clutch steels  (Read 1043 times)
Offline greenjeans
  • 1972 CB750K2
« on: May 23, 2008, 10:52:23 AM »
After reading this post:  http://forums.sohc4.net/index.php?topic=29374.0
I decided to take out my clutch and double check the steels, friction discs etc.  Been having a little trouble finding neutral.   Also put some addtional holes in the basket for better oiling.
On the clutch steels...should the "cut/sharp" edge (the sharper edge vs the rounded/stamped edge) be facing
TOWARD the engine or AWAY from the engine ?
Thanks in advance.
Offline rbirkhan
Re: Lunchtime quickie.....clutch steels
« Reply #1 on: May 23, 2008, 11:58:32 AM »
Im just guessing but I dont think it matters as long as you have a steel then a plate then a steel etc
Offline Magpie
« Reply #2 on: May 23, 2008, 02:53:56 PM »
I don't think it matters as long as they all face in the same direction.
Cliff.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: May 23, 2008, 06:09:27 PM »
My understanding of this is as follows, when the plates are stamped out, they end up ever-so-slightly dished.  So, having them all pointing in the same direction gives you this:
instead of this:
which makes things work ever-so-slightly better.
mystic_1
- John Augustus Shedd
GraveRobber
« Reply #4 on: May 23, 2008, 07:41:47 PM »
I know this is going to sound odd but what weight oil are you using? I finally fixed my clutch problem by switching to 30W oil.
« Reply #5 on: May 23, 2008, 08:40:30 PM »
You got a lunchtime quickie???? Sheesh.
The "sharp" sides were originally facing the engine. But, like Magpie said, so long as they all go the same way, no matter.
Offline Raul CB750K1
« Reply #6 on: May 24, 2008, 02:16:33 AM »
The few times I have had a lunchtime quickie, clutch plates would have been the last thing that crossed my mind.....  ;D
Offline greenjeans
  • 1972 CB750K2
« Reply #7 on: May 24, 2008, 12:00:52 PM »
Still in the honeymood phase ;)
Fresh oil & some extra holes in the basket seem to do the trick.  Thanks fellas
