Author Topic: Ham-fisted shade tree mechanic needs bolt & tap size  (Read 863 times)
Offline greenjeans
  • 1972 CB750K2
« on: May 26, 2008, 12:49:19 PM »
'72 CB750K
My 2 right side pipes had developed small holes along the seams (HM341's) and I took them off
to try and fill them.  Used some sort of muffler repair in a can - actually seems to be working.
Anyway, I picked up some new copper gaskets for the exhausts and when re-installing I put the gaskets in
and then mounted the exhaust to the head and tightened down....screws almost seemed cross-threaded
so I want to chase the threads and put new screws in there.
Anybody know what size those screws are ?
And, aren't ALL the exhaust flanges identical ? (In theory)  I can't get the number 4 pipe to fit all the way
onto the flange, BUT, they don't seem to slide on far enough (specifically the number 4 pipe) there is almost 1/8"
of an inch left that it could slide onto the flange.
I've tried taking it off and inserting the flange into the pipe...same result - doesn't slide far enough on there to
cover the slits on the header pipe.  I have cleaned everything, so there's not any rust/debris keeping me from sliding them on further.
Are the flanges numbered ?
Am i going to have to take everything apart again ?  Hate have to wait for new exhast gaskets again
« Last Edit: May 26, 2008, 12:51:51 PM by greenjeans »
fuzzybutt
Re: Ham-fisted shade tree mechanic needs bolt & tap size
« Reply #1 on: May 26, 2008, 12:50:44 PM »
i believe theyre 8x1.25mm
Offline CBGhia
« Reply #2 on: May 26, 2008, 01:55:02 PM »
Does the flange have to sit flush?   As long as the gasket is compressed and there is no leak, shouldn't it be fine if it sits out just a bit?
And dude is you are ham fisted,  I have no idea what I am, because you have done some great work on the bikes I got from you.
fuzzybutt
« Reply #3 on: May 26, 2008, 06:05:06 PM »
if the holes are too thrashed try this................. when i was heavy into air cooled vw's a commin problem on a car with the original exhaust was the exhast stud snapping off when trying to remove the exhaust. if the hole got buggered up there was something called a "step stud" larger diameter to screw into a newly enlarged and re-tapped hole in the head and the standard size on the other end. i THINK vw heads and sohc 750's use the same diameter/thread count studs. might be a possibility.
