Author Topic: 1977 cb550 , need help  (Read 1002 times)
1977CBFOURK
« on: May 26, 2008, 01:28:05 PM »
Cleaned the carbs on a bike that had not run in 5 or so years. started right up once reassembled. lots of backfireing and 1st and 2nd pipes are very cool compared to the 3rd and fourth pipes. Switched the plugs around to see if that was the problem but no difference. I have new plugs , and oil filter, and new air filter on the way right now. Any ideas on why the first two dont seem to be fireing?        ???
Re: 1977 cb550 , need help
« Reply #1 on: May 26, 2008, 01:29:46 PM »
more carb cleaning
1977CBFOURK
« Reply #2 on: May 26, 2008, 01:32:26 PM »
how do the idel jets come out? do they just pull or screw?
« Reply #3 on: May 26, 2008, 01:34:15 PM »
The 77-78 K model PD carbs have pressed in jets.  I use a parallel jaw pliers to pull them straight out.
Offline ieism
« Reply #4 on: May 26, 2008, 02:52:32 PM »
Make sure the hoseclamps around the rubberboots are on tight.
If they are.....more carbcleaning :(
---cb550---
1977CBFOURK
« Reply #5 on: May 26, 2008, 03:26:09 PM »
make that two  :( :(
