Author Topic: kickstarter doesn't engage in neutral  (Read 972 times)
xProjectx2501
« on: May 26, 2008, 08:44:25 PM »
When I bought my bike, the PO said the engine was stuck. Turns out it wasn't, neither was the clutch. (rolled it down a hill in neutral and put it into first to get the coerce the engine into turning over) The problem was that the kickstarter didn't engage the main drive in neutral. No idea why, but it does engage in every other gear. Any ideas what the problem could be?
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: kickstarter doesn't engage in neutral
« Reply #1 on: May 26, 2008, 08:52:24 PM »
What model of bike are we talking aboot?
 Matt.
Gallery at:
xProjectx2501
« Reply #2 on: May 26, 2008, 08:57:14 PM »
That would help, wouldn't it. :P  1972 CB350F
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: May 26, 2008, 09:06:07 PM »
Can't wait for the answer.....Happened to the CL350 today. I haven't looked at it yet because I lent it to a friend for this parking lot test tomorrow.
Offline kghost
« Reply #4 on: May 26, 2008, 09:14:55 PM »
My 350 doesn't engage in neutral with the clutch IN.
Its inherent to the design.
It will with the clutch out.
ALso will engage in any gear with the clutch IN
Stranger in a strange land
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #5 on: May 26, 2008, 09:24:57 PM »
Like Kghosts says... it's because of the design.
The kick starter works backwards through the transmission by engaging one of the transmission gears which turns the clutch to turn the engine.
If the clutch lever is pulled in (disengaged) the power flow is broken and nothing happens
 Matt.
Gallery at:
xProjectx2501
« Reply #6 on: May 27, 2008, 12:34:03 AM »
Forgive me, I should have clarified, but it doesn't engage with the clutch in or out. Tried it both ways just to make sure I wasn't being foolish. I'll try to remount it into the frame again tomorrow and double check that I'm not an idiot. Hopefully I'll pass that test.
