Author Topic: Gas Tank Restoration?  (Read 2231 times)
trism18
« on: August 23, 2005, 08:52:08 PM »
What all is involved in cleaning/restoring a CB750 gas tank?  How does one clean the inside, then seal it?  What is the best method of paint removal for the outside?  How does one deal with rust?  Any favorite products to get the job done right?  Thanks for the input.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Gas Tank Restoration?
« Reply #1 on: August 24, 2005, 03:02:34 AM »
Read through these in the FAQ, lots of info on the subject.
http://www.sohc4.us/forums/index.php?topic=2893.0
Offline Chris Liston
« Reply #2 on: August 24, 2005, 05:40:30 AM »
http://www.gas-tank.com/
This is where I sent my tank.  Costs some cash but it will NEVER rust again.
Chris
1976 CB550F Cafe in progress
dtaxman
« Reply #3 on: August 27, 2005, 10:43:00 AM »
I bought a 1977 with tons of rust in the tank.  I used a product called Kreem.  It worked great.  It removed all the rust and then comes with a sealer.  The kit cost about $20 at a local motorcycle shop.  It is easy to use.  It took me about a week because you have to let it sit over night.  Hope this helps.
dtaxman
Offline Bodi
« Reply #4 on: August 27, 2005, 11:16:09 AM »
The tanks came originally with bare steel inside, and this lasts pretty well. If it doesn't leak (ie no spots have rusted right through) you can just clean it and use it.
Use a phosphoric acid solution, hardware stores sell it as concrete etch to use before painting a garage floor. This will attack aluminum, so remove the petcock and use a rubber stopper. Pour some in, swish it around, leave it an hour or so. Adding some pea gravel and shaking it will help lots. Don't get the acid on you or your clothes though! The rust is always worse at the bottom where any water in the tank collects.
Rinse well with plain water and dry thoroughly. A hair dryer in the filler woks, or just leave it in the sun for a while.
If your local gas contains ethanol then you will never have free water pooling again, if not add some gas line antifreeze occasionally and expecially for long term storage if you leave gas in the tank.
Use an inline gas filter. There will be little specks of crap in your gas (rusty tank or not) and they tend to stick in the carb float valves and cause overflowing.
If you actually have leaks, use a Kreem or POR-15 kit. Both work the same and there are proponents of either one over the other. They coat the inside with a hard plasticy goop, sometimes this peels off or dissolves and causes way more problems that a plain steel surface would.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #5 on: August 27, 2005, 03:12:00 PM »
For clarification, POR-15 is dramatically different than KREEM.  The prep is the same, but the POR-15 'liner' is not plasticy at all.  It is essentially paint, and provides excellent coverage.  I'd highly, highly recommend POR-15 over KREEM.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
