Author Topic: 750 chop "The Chipper"  (Read 8848 times)
BillKat
« on: May 28, 2008, 12:04:57 PM »
Hi all,
I've had this a couple of months, but not got much done due to other stuff going on, but made a start so thought I'd start me a build thread. Looks fairly OK here but everything is a mess:
It seems kind of small, so it sort of called the Chipper for no particular reason. Although there was a bicycle when I was a kid called that, maybe thats what it came from. Seems to have stuck till a better name comes along.
Brakes seized, wheel bearings shagged, rats nest wiring etc. Exhaust had some fence wire rammed up it's chuff as a baffle. Exhaust threads are monkey'd and different sizes. All the usual. Not much to show at the mo, but pulled out the engine and magic spaghetti:
Not much in the way of plans yet, but I'm going to try making a tank, see how that goes. If that works all the rest will follow.
Flat seat, different mudguard/fender. Fairly 70s/early 80s type thing I guess is the aim.
I've opened up and made one-off faces for my Wing's clocks, so will prob have a go at these ones too.
I'm waiting on a top for my new work table and then will see about piling in. The sideboard with kitchen table top nailed to it finally gave out after 10 yrs. Made a steel table frame, and chopped up the sideboard for a set of drawers and shelves. Bargain  :)
Next up, make something to hook up the motor to my car engine stand.
fuzzybutt
Re: 750 chop "The Chipper"
« Reply #1 on: May 28, 2008, 01:29:22 PM »
if you decide not to use it can i have dibs on that mustang tank?
BillKat
« Reply #2 on: May 28, 2008, 02:09:54 PM »
That's going to donate a filler to my home-brew tank and an oil tank, it's rusted out ...
75modrat
« Reply #3 on: May 30, 2008, 10:24:35 AM »
Truth be told...I like that frame...Alot!
Frank
BillKat
« Reply #4 on: May 30, 2008, 04:06:14 PM »
Clean & simple lines eh Frank, wasn't sure about it at first but it's grown one me,
cheers
Bill
Offline bunghole
« Reply #5 on: May 30, 2008, 04:35:34 PM »
Here's the motor mount design I copied (which I think was copied from somewhere else).  Works great so far.
http://forums.sohc4.net/index.php?topic=29364.msg309143#msg309143
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
« Reply #6 on: May 30, 2008, 05:18:19 PM »
I was trying to work out why that frame is so long, then I realized that the area behind the vertical downtube is where the gearbox would have been mounted when that frame was originally built for a Harley or a British twin? Nice bike mate, but it needs a springer front end! Cheers, Terry. ;D
BillKat
« Reply #7 on: May 30, 2008, 05:25:25 PM »
bunghole thanks for that, great, that's like what I'd planned. Bought some thickwall sq tube and studding to make up a similar shape thing to that. Good to see the basic thing in action.
Terry, could be, good shout mate. The front downtubes narrow together and it's a bit of a pain to get at the exhaust bols/studs cos they're close, so I did wonder about it's parentage ...
Springers would be the dogs danglies but the old cash situation is too tight unfortunately  ::)
« Reply #8 on: May 30, 2008, 05:32:43 PM »
No worries Bill, it looks good anyway. Kinda reminds me of my cousins 1944 Indian Chief. There was a CB750 chop in an "Iron Horse" mag (before they went "Harley only") in 1980 with a really neat bobbed CB750 chop like yours, it was done so well it could have been a factory job. I gave that mag away 20 years ago when I was cleaning out my house, but I wish I had it again now, I'd send it to you! Cheers, Terry. ;D
BillKat
« Reply #9 on: May 30, 2008, 11:23:04 PM »
 :) Cheers mate,
Bill
BillKat
« Reply #10 on: June 24, 2008, 09:22:08 AM »
Small update. Slow progress due to various life-related things... Chopped the 'guard up:
As it was much too big a radius, I did a lot of pie-cuts in the edges, pulled it in and welded 'em shut. All a bit of a learning curve as it's my first real dealings with thin steel, 1mm or less.
Template of clear placcy, quick squirtage of the old matt black, and we have a template for t'other half:
Chopped out some holey rusty sections & put new steel in. Hammered the compound curves, unfortunately the el cheapo body hammers are'nt much better that those little blocks of cheese on cocktail stick things  :)  though lack of skill is likely more of a prob ... Starting to edge it with 3mm rod:
All edged:
Finally got the makings of a work table / decent work surface so I can set about playing with ideas for the tank before too long (hopefully...)
Offline bzr
  • I'm not here.
« Reply #11 on: June 24, 2008, 08:00:41 PM »
NA NA NA NA na na NA NA NA NA NA NA na na NA NA NA NA BATMAN!
1976 Honda CB550F
BillKat
« Reply #12 on: June 25, 2008, 06:04:36 AM »
 ;D
75modrat
« Reply #13 on: June 26, 2008, 09:24:03 AM »
Bill,
What happened to the original fender? I kinda liked it (ok fine I loved it). Not that it matters because it is your beautiful bike. The new fender could look totally awesome too. I may be partial to the fact that the other one was finished. My project has been going so long I hate looking at unfinished parts. My problem not yours. Keep up the good work!
BillKat
« Reply #14 on: June 26, 2008, 11:29:06 AM »
Hi modrat, I just didn't like it, I've got vague ideas for the general thing and it didn't fit in. It was full of holes and rust anyway, plus the lower part round the leccy box had been beaten & cut none too nicely.
General idea for the bike has come from a visit to a museum where they had this medieval armour and weapons and the metalwork was completely awesome, and the shapes inspiring. I can't do anything remotely like those guys did (how on earth did they manage it?), but the shapes, I'll try & borrow something from those...
75modrat
« Reply #15 on: June 26, 2008, 12:43:50 PM »
Bill,
Hopefully you didnt take any offense to my inquiry. Your preferences are what matter. And I also understand having to make changes because parts you have are not really usable. Also, I do like the new idea you have going also. I like the uniqueness of it.
BillKat
« Reply #16 on: June 26, 2008, 01:39:06 PM »
No offense at all mate, everyone likes different things, which can only be good. Helps bring all these different bikes into being. If folks don't like it, I'm not worried in the slightest, sort of like if someone prefers Jim Beam to Jack Daniels, well that's their thing and fair enough. Some guys take stuff personally I suppose. I'm just doing it for me and anyone else liking it is a bonus, no worries  :)
Offline bradweingartner
  • 74 CB 550 x2
« Reply #17 on: June 28, 2008, 04:42:56 PM »
I like a good hard tail to be sure.
Working on a xs650 chop in simliar nature to that one. Only lesson that setup taught me was that bright colored batterybox and oil tank on a black bike really detract from everything else.
Love what you've done with the fender. Especially that YOU did it, and didn't just pick up the latest accessory catalog and ordered up something.
BillKat
« Reply #18 on: June 29, 2008, 04:12:54 AM »
Thanks for the nice words Brad. Good thing on the oil tank/sparks box too, noted... not made a colour choice yet.
BillKat
« Reply #19 on: August 08, 2008, 07:16:20 AM »
'English Chopper edition' or 'More Ambition than Talent or money'
S'been a while, due to work probs (lack of). Decided to make something of the manky pitted plain fuel caps rather than buy new (skint y'see).
So first we fired up the supa hi-tech CAD software (Cardboard Aided Design) and made a pattern:
Next the water jet and english wheel:
Had massive argument with self. Fired my ass. Broke some stuff. Re-hired self. Did lots of REALLY LOUD SHOUTING!
Cut the shape and curved them to fit the cap, checking each had the same curve. Stuck it on: well roughed up, and chemical metal.
On to the "lathe", with some rod from an exercise bike (which also provided material for the tot rod chassis and Amazon exhaust...). Made some spikes. Resting the rod on the grinders guard and spinning it, with a bit of care they came out pretty OK. Chopped and stuck spikes on.
Some chem metal and filler round the sides, and a quick quirt of poor man's chrome to check for shape.
The tank
Worked out an idea for a shape that would seem do-able for a first go at this, with an illusion of compound curves, and OK with available tools (see above). Made a carboard fish first:
Rough ideas fer shapes & stuff came from seeing medieval armour & weapons in a local museum. Awesome metalwork. So it's a theme bike... and in due course I'll be sticking stuff all over the sucker....  :)
Made the tunnel over 2" tube:
Welded tunnel to floor. Add central spine, for a ridiculous idea that might not happen. Cut out and shape the tops:
Made some metal A's from 3mm to brace the floot and take a pair of bungs made by Trabby Wayne (or lad of Wayne, cheers chaps), for hidden mounts. Also plates for another pair of bungs, and fuel tap bosses liberated from the old mustang tank.
Clamped on the hi-tech welding table (wktop offcut on tins of paint, ally sheet & on top):
Some uprights were tacked to the floor, to make the height and angles right. Cutouts for the fuel cap necks (cut from mustang tank), and on with the tops. Sides next, and then the filler necks.
Things learnt:
Must have more thin metal practice.
Measure three times and cut once: came out wider than planned due to idiocy. Will do things with paint & shapes to address that though.
Love doing this stuff. Can't wait to try another tank...
martino1972
« Reply #20 on: August 08, 2008, 10:16:54 AM »
that's some fine metal crafting your doing there young man........
Offline MJL
  • Don't listen to me, I'm no
« Reply #21 on: August 08, 2008, 12:34:01 PM »
Another board I am on has a guy from Pakistan. His shop is very primitive compared to a modern shop, yet they turn out inspiring metal craftsmanship.  I am searching for his pics and videos and will post them in the off topic forum.
Offline mystic_1
  • 1970 CB750K
« Reply #22 on: August 08, 2008, 04:05:29 PM »
That tank looks great, BillKat.  I've seen far worse stuff come out of supposedly-professional fabricators.  It's even more impressive in that this was your first tank.  Looking forward to seeing what else you come up with.
mystic_1
- John Augustus Shedd
Offline CBJoe
« Reply #23 on: August 08, 2008, 06:18:37 PM »
 :o  Wow...LOVE THE METAL WORK
I don't think i'm gonna blink until I see the finished project.  Keep it up and keep the pictures coming.
Cheers...Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
BillKat
« Reply #24 on: August 09, 2008, 02:10:00 AM »
Thanks a lot for the encouragement folks  8)  Hope it works out. Off to leak test it now, went round it spot-melting anything looking suspect last night so fingers x'd.
MJL that'd be good. Like the guys in Cuba, how they keep those American cars going and how they make fantastic stuff from next to nothing - respect...
