Author Topic: Cables for Lower Bars  (Read 2258 times)
Trumpet
« on: April 11, 2005, 01:21:20 PM »
Looking for ideas on what options might be out there for shorter cables when using lower bars/clubmans?
Offline jwalters
Re: Cables for Lower Bars
« Reply #1 on: April 11, 2005, 02:45:35 PM »
Trumpet, I too, installed some clubman bars and have too long throttle cables now.  I anxiously await replies!
jesse
1997 Suzuki Bandit 1200S
1972 Honda CB 750 K2 "Cafe Racer"
tgascon
« Reply #2 on: April 12, 2005, 05:25:45 PM »
Ditto for me!
Todd
AndreRA3
« Reply #3 on: April 12, 2005, 05:47:08 PM »
Yup!!!  ;D
My main problem is the brake line, which now takes an "S" turn before dividing into the two calipers (dual disk set up done by P.O.).  No leaks, nothing major to worry about, and I'll probably fix it one day when I install custom fit steel braided lines.  As for the throttle and clutch, I just let them stick out the front a little bit.  At lleast the bike doesnt rev up when turning the handlebars to the max like it used to.  Or if it does, I haven't paid attention to it.
but if anyone knows of shorter cables, let us all know!!!
Justin_NJ
« Reply #4 on: May 09, 2005, 10:41:35 AM »
Anyone found a solution for this?
Offline Bryan Boyle
  • SOHC4 #47 ...one of the Old Pharts
    • The Other Hobby: Restoring Lotuses
« Reply #5 on: May 09, 2005, 11:04:26 AM »
Yeah.  depending on where you are in nj...bring your bike over to john's cycle on us 22 in whitehouse.
He has the tools and fittings to custom make cables in whatever length you need.
Call first...they are open tues-sun.  908-534-2222
Bryan
SOHC4 #47
Proud member since 1994, active on and off
Commercial Pilot/Flight Instructor-Instrument/A&P
Morrisville PA
'63 CA95, '64 CA77, '73 CB350F, '73 CB350F, 2 Lotus Europas and Lots of Parts All Over The Place
