Author Topic: VHT engine paint - example pic. Rearset info too.  (Read 8187 times)
Offline 750deepsouth
« on: August 24, 2005, 02:20:13 PM »
A few of us have chatted in the past about engine paints & I said I'd pop up a pic when I got my motor completed.
Here it is, VHT high temp  SP127 Universal Aluminium
Andy
« Last Edit: August 25, 2005, 02:39:45 PM by andynzl »
Offline DrMark
Re: VHT engine paint - example pic
« Reply #1 on: August 24, 2005, 03:55:58 PM »
Darn Nice....Look Terrific....Might be a new winter project now....
1978 CB550K
1983 CB650SC Nighthawk
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: August 24, 2005, 08:07:30 PM »
I'm more interested in what's going on with the rear sets  :o
« Reply #3 on: August 24, 2005, 11:01:02 PM »
Good job Andy,just beware of fuel sytem cleaner type additives, one leaking carb (stuck needle and seat) ate my VHT satin black engine enamel a year after I'd painted my cases! Cheers, Terry. :'(
Offline MikeDeB
« Reply #4 on: August 25, 2005, 04:50:26 AM »
Andy
Andy, that looks sweet!   ;D  Your CR project is coming along nicely.  BTW, I've found a new way to open and close gauges for refurbishing the faces.   ;)
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: August 25, 2005, 04:59:08 AM »
Stop teasing, what's your new way?  ???
motodude
« Reply #6 on: August 25, 2005, 07:56:07 AM »
Here's a pic of mine, same paint.  That stuff is a near dead-on match for Honda AND Kawasaki flat silver:
« Last Edit: August 24, 2007, 01:22:40 PM by Glenn Stauffer »
Williamsd
« Reply #7 on: August 25, 2005, 10:28:27 AM »
Great looking paint job!...  except for not looking "stock" I would think about re-doing mine.
I just did the 4-to-1 header and the top-end on my 650 Nighthawk in flat black.
The only problem was that the colour did not seem consistent on the pipes.
It looked a bit grey in spots.  I know that I shook it up well.  :(
Regardless, it seems to be holding up well in both applications.
I will redo the header and paint the lower-end this winter.
pwgabor
« Reply #8 on: August 25, 2005, 01:16:12 PM »
Hey Guys, I'm new to motorcycling. My Dad has had a 1981 CB650C for a few years now and I'm going to be helping him restore it and hopefully inherit it. I was wondering about painting the engine. How far do you have to tear it down? I'm going to replace the head gasket and thought about painting the engine.
Thanks,
Paul
Re: VHT engine paint - example pic. Also, rearset info
« Reply #9 on: August 25, 2005, 01:47:15 PM »
I've fitted a modified set of MC rearsets to my frame. MC Enterprises of California made custom motorcycle accessories in the 1970's and these rearsets could be fitted to both the 750 four and the 500 four. I bought this kit on Ebay, and it came to me in its original packing - a faded L A Times newspaper from the 70's. The side plates should be held to the frame with metal clips bolted onto the frame tubes. The plates are rectangular. I shaped the plates to fit the angles of the frame tubing &, welded them to the frame rather than bolted onto clips. The pivot points were improved as well by machining pivots with closer tolerances - this has removed all play from the lever action.
They look a bit chunky, but do the job.
Good point. We mustn't think that a paint is completely bullet proof  ;D
{you'll get that joke, Terry !}
The preference is to strip all the way, get the cases cleaned really well. But you can probably do a fair job if you are careful, with the motor in one piece.
grapppa
Re: VHT engine paint - example pic. Rearset info too.
« Reply #10 on: October 24, 2005, 04:24:31 AM »
Andynzl,
How did you get that aluminum to be so clean and shiny or did it start that way?  BTW, regarding engine case paint I tried the duplicolor 1615 and it doesnt match - to my eye - will check out the Sp127 uni. aluminum...
Offline cb(r)
« Reply #11 on: October 24, 2005, 08:24:50 AM »
that engine does look great.  I have used vht years ago on a v8 ford that I had build for a friend of a friend.  but it did not turn out that nice.  the only questions i have is how it will hold up to the repetive cleaning of road grime?  would you powerwash the engine or what?  continue the good work!
oh ya and thanks for the rear set pics.  gives me Ideas for my bike.
mylittleho
« Reply #12 on: October 24, 2005, 02:25:17 PM »
dulpicolor 1606 (or is it 1616) looks just like polished aluminum.. I'll have to post pictures later..
rucorey
« Reply #13 on: October 24, 2005, 04:01:58 PM »
Great work on the piant. I bidded on a set of those rears last month and lost out at the last minute. Can you take a shot of the bike from a few feet back? I was curious how they would actually look together on the bike as a whole. Maybe next time I'll pony up more cash.
Thanks!
« Reply #14 on: October 24, 2005, 04:22:09 PM »
Click on his name and go to his web site ;)
« Reply #15 on: October 24, 2005, 04:53:42 PM »
I guess in time, the addition and removal of grime will eventually get to the paint finish, just as the original finish on Japanese Bikes of this area were all made to look a bit crappy over time. I think I'd use a gently method than power washing.
I had the motor cases chemically cleaned in a motor shop.
Just in case of confusion - the shiny bits eg cam cover, clutch cover - were bead blasted then ceramic coating applied by HPC  http://www.hpcoatings.com/  The gearbox cover is hand polished, with a hi-temp clear applied {always experimenting!}
I've only used the VHT on crankcases, barrells, and head.
« Last Edit: October 24, 2005, 05:14:42 PM by andynzl »
Offline Kevin D
  • SE Michigan
« Reply #16 on: October 24, 2005, 08:06:45 PM »
I finally found VHT at Autozone for $10 - the day after I used the Duplicolor 1606 on the oil filter housing. I don't care for the Duplicolor - way too shiny and bright. Your photos with VHT look terrific.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #17 on: October 24, 2005, 09:16:32 PM »
Have you been up all night or are you at work ?
« Reply #18 on: October 24, 2005, 09:21:02 PM »
Kevin, yeah some of those other aluminium colours are too bright
Sam: days off, we are 13hr behind you at present so its late Tuesday afternoon 5:19pm here
Just finished taking the CB750 for a run after mowing me lawns. We have to take advantage of our birght sunny mild days  :D
« Reply #19 on: October 24, 2005, 09:26:12 PM »
It's to wet to cut my grass, it's been bad for 3 weeks now.
« Reply #20 on: October 24, 2005, 09:43:51 PM »
Your only hope now is for it to become cold as well, so that it stops growing  ;D
« Reply #21 on: October 24, 2005, 10:08:49 PM »
It did'nt last year, I cut the grass Christmas eve and again the second week in January.
I dont mind cutting the grass, it's just that you can't realy do it when it's wet :(.
I am off home in an hour, will see you next week end.
Sam.
5bassman
« Reply #22 on: October 25, 2005, 12:41:16 PM »
Did you use the same paint on the case as you did the fins?
« Reply #23 on: October 25, 2005, 01:39:46 PM »
Yes, head, barrells, crankcases, all the same.
