Author Topic: Non-'glass single cafe seat-pix or suggestions?  (Read 5106 times)
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« on: June 01, 2008, 11:04:44 AM »
I was thinking of upholstering a flat seat pan to the rails and creating a 'cap' tail end to mimic the edges on my stock '78 750k tank and NOT using glass. Anyone made a seat out of sheet metal or aluminum?
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Re: Non-'glass single cafe seat-pix or suggestions?
« Reply #1 on: June 01, 2008, 11:34:32 AM »
I run a Kawi Z1 ducktail on a 73 750. You have to make a seast and an inner fender piece.
as to what you mentioned, go for it.. nothing to loose.start of with cardboard templates taped together till you get your look.
I would like to recreate a Z-1 ducktail in Aluminum, partly to get a better fit to the frame, and because brushed or polished alloy would look nice..
Offline kghost
« Reply #2 on: June 01, 2008, 11:40:31 AM »
Yeah...what is it you wanna know?
Mines further along now but....
Stranger in a strange land
Offline DME
« Reply #3 on: June 01, 2008, 01:32:18 PM »
Made my seathump out of 1,5 mm sheet metal.
Made it in two sections, the front "straight" piece and the rear "rounded" piece.
No other tools than a carpentry hammer and some blocks of wood cut in various shapes. Took a lot of hammering.....  ;)
Turned out like this:
More pics here: http://gallery.sohc4.net/main.php?g2_itemId=5120
Cheers
Dan
fuzzybutt
« Reply #4 on: June 01, 2008, 02:37:31 PM »
i have a tail piece from an h2 i've been thinking of modifying to fit a 74 750k seat pan.
Offline DarkRider
« Reply #5 on: June 01, 2008, 05:29:33 PM »
I may play around with ideas like this once i get the F home.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #6 on: June 02, 2008, 06:01:53 AM »
Thanks for the response.
My concern is that since I plan to keep the stock '78 tank, the trad bubble or ducktail will look out of place with chunky tank.
I may eventually swap the tank, but since it's in great shap rust-wise, I'd rather run it and build the seat/tail around it.
Is there another cafe seat style besides the duck and bubble that I've missed?
troppo
« Reply #7 on: June 02, 2008, 06:06:43 AM »
you could always take a mould of the tank in glass and lay up a seat tail from that
Offline hopterfixer
    • My flickr Gallery->
« Reply #8 on: June 02, 2008, 06:29:32 AM »
What about finding a donor tank and making a seat like this?  I used a cb350 twin tank as a donor mounted on a factory pan.  If you used a K8 tank, they would match and you would have much more storage than I do  ;)
« Last Edit: June 11, 2008, 06:00:20 AM by hopterfixer »
Offline kghost
« Reply #9 on: June 02, 2008, 06:30:28 AM »
Yeah that was a neat trick hopter....
Very cool.
Offline Klark Kent
« Reply #10 on: June 02, 2008, 01:31:26 PM »
Very cool.
+1
you like the number 8 much?
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline cleveland
« Reply #11 on: June 02, 2008, 02:24:31 PM »
I've been thinking about going this route.  The problem is that my donor seat pan is too rusty.  I have another one, but I think it will be just as rusty when I pull the foam.  :(  I may just have to make one.  :-\
Offline hopterfixer
« Reply #12 on: June 02, 2008, 03:36:09 PM »
Very cool.
+1
No I just copied one of the numbers on my plate to hide its true identity  ;)  I think blurred licenses plates are distracting when you are trying to look at a bike.
How rusty is the pan?  Have it sandblasted and take a better look at it.  I had a good pan to start with, and luckily the parts of the tank I needed were not rusty.  It would not be hard to make a basic pan, depending on how you want to mount the cowl section.  You could mount the cowl part to the frame and make a flat "seat pan", using the factory hinge, so that only the seat area hinges open.  Good luck.
« Last Edit: June 02, 2008, 06:33:33 PM by hopterfixer »
Offline cleveland
« Reply #13 on: June 02, 2008, 04:21:02 PM »
Very cool.
+1
How rusty is the pan?  Have it sandblasted and take a better look at it.  I had a good pan to start with, and luckily the parts of the tank I needed were not rusty.  A pan would not be hard to make a basic pan, depending on how you want to mount the cowl section.  You could mount the cowl part to the frame and make a flat "seat pan", using the factory hinge, so that only the seat area hinges open.  Good luck.
My plan is to set up a seat similar to yours with the exception of the brake light.  I am putting a smaller one on the rear fender.  If I do it that way, I'll be able to throw the stock seat back on when the little lady wants to go for a ride.  ;)
troppo
« Reply #14 on: June 03, 2008, 01:45:08 AM »
Why not use the donor seatpan as a mould, clean it up and make sure its very rigid by using any means at hand (tape etc) and then take a fibreglass copy from it, you can use that as your seat base, it will still work with the original hinge and latch and all the rubber mounts, from there you can shape anything you want on it
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #15 on: June 04, 2008, 06:33:42 AM »
working on getting a $10 tank. I have an idea for the pan as well. I'll post pix as I make progress.
