Author Topic: just my luck  (Read 1864 times)
nashport_native
just my luck
« on: August 25, 2005, 05:55:28 PM »
I bought 2 cb's 76 (running no title) and my 78 that is my now daily rider ( as much as ohio permits) looked over the 76 today( using it for a chopper) and the stupid thing is a auto......only has 12k miles on it, so im not sure what im going to do now......
any one wanna swap a 76 auto 750 for a manual 750??
anyone here had or owned a 750 auto? how much slower vs the manuals? the bike should weigh around 400 lbs when done so it would be faster than the stock cb, not that Im looking for a rocket but it would be nice to have around 70 hp (rear wheel)in a 400lb package...
Offline chrometank
  • cb750 1976 owned 33 yrs
Re: just my luck
« Reply #1 on: August 26, 2005, 06:51:19 AM »
ild hang on to that auto,might be worth something one day
nashport_native
Re: just my luck
« Reply #2 on: August 26, 2005, 01:11:36 PM »
no title though.......I am gonna keep it( well part of it) gonna use it and make my chopper as planed....being the auto will make it even more unique.
Offline Uncle Ernie
Re: just my luck
« Reply #3 on: August 26, 2005, 06:33:10 PM »
The VJMC mag ish before the current one was dedicated to that model
Re: just my luck
« Reply #4 on: August 26, 2005, 07:32:27 PM »
Nashport,
To get 70bhp at the rear wheel of an auto you will require the following.
Supercharger, turbocharger, neat nitro methane injected with large doseage of nitrous oxide and a jet or rocket at the rear end.
This will take the weight of your chop to between 900/1,000lbs.
On a more serious note a stock K series motor in perfect condition makes 67bhp at the crank (60bhp at rear wheel).
I seem to remember reading (probably someone will come along and confirm this) that the auto makes no where near this amount.
I don't know why the motor was detuned so much but there you have it, just stick it in your chop and enjoy.
Cruise on baby, cruise on. ;D
nashport_native
Re: just my luck
« Reply #5 on: August 26, 2005, 08:27:27 PM »
thanks for the info. I'm guessing the trans wont take the power and was detuned to keep it living longer....
even still in a bike that weighs 150-200 lbs less, it will still have pleanty of power.
Re: just my luck
« Reply #6 on: August 26, 2005, 08:49:44 PM »
I dont reckon you will be able to get that much off it without the use of exotic metals.
I run a CR750 race bike almost to full 1970 Daytona spec and it still weighs in at 180 kgs (396lbs).
You can but try, so good luck with your project.
Regards Sam.
Re: just my luck
« Reply #7 on: August 27, 2005, 03:05:16 AM »
Well on the old boards, there was a guy (can't think of his name) who ran a drag bike based on an auto, and swore by em! They were turboed, and he reckoned the auto trans was plenty strong enough to handle it, and the two speed auto's ratios were ideal for the 1/4 mile.
They were detuned with different heads and smaller carbs (24mm?) and heavier than the manual transmission models, but were excellent tourers with reasonable top end speed, once wound up. For a chopper it'd be ideal for comfy cruising, I'd like to have an original one, just because they weren't popular here in Oz and weren't imported in big numbers.
I'm sure you could fit a K or F head, cam, carbs etc to give it a bit more punch, and not having a clutch lever would give your apehangers that "minimalist" look, particularly if it's gonna be sans front brake too. Go for it! Cheers, Terry. ;D
