Hello,
Got a new (to me) CB750 project. It is a 1972 (K1). I know much on the front end is not correct K1. For example, the fender appears to be off a 77 or 78 and the chromed headlight ears should be painted. So, I know the front end probably has been replaced at one point.
The forks in a lot of ways look correct except the air shrader valve on top. I know the earlier CB750's weren't air assisted, but was there air forks on later models?
![Huh ???](http://forums.sohc4.net/Smileys/default/huh.gif)
If so, any guess what these might be off of??
If everything else seems solid as I get deeper into this project this winter, I will likely try to get the bike back to as many correct parts as I can, but it would be nice to know what I'm starting with.
Any guesses as to what year this front end it from?
Thanks
![](http://www.macesoftware.com/cb750/forks_pre01.jpg)
![](http://www.macesoftware.com/cb750/forks_pre02.jpg)
