Author Topic: HT Coil / spark plug leads Numbers.  (Read 1224 times)
Hop on a Honda
« on: August 25, 2005, 09:45:10 PM »
 Again!.
I am going to rebuild my coilds leads etc.
I have the burning ambution to excell if I can, in this massive reconstruction and get it right in one go.
I need the White on Black sleve ID Numbers to slide over the HT Leads IE 1/2/3/4
These are I believe heat shrink and can be obtained.
Question is? Where & Who has them.
Where do ya Get It!!
Dave Down Under.
Hop on a Honda
Re: HT Coil / spark plug leads Numbers.
« Reply #1 on: August 29, 2005, 02:54:18 AM »
I'll try to regenerate this thread.
i need to know where the hell you can buy the numbers that fit ovre the HT leads IE 123&4.
Where do ya get them/
I have just installed 4 NGK IRIDIUM Spark Plugs.
It gives me another gear!!
Good stuff
Dave Down Under
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #2 on: August 29, 2005, 03:17:25 AM »
I have no idea where you can buy the HT lead numbers but I agree with you about the iridium spark plugs. The bike starts easier, idles smoother and goes better.
Suggest that you try the motorcycle wreckers for your lead numbers. Pat from Aus
Regards
Pat from Australia
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: August 29, 2005, 03:17:44 AM »
Came across this..
I picked up a set of "heat shrink" numbered sleeves at a local speed shop.
Hop on a Honda
« Reply #4 on: August 29, 2005, 08:55:20 PM »
Thansk Bob.
"Speed shop" is that a 4 wheel thing any clues where in Down Under Country not Hazzard County!!
Dave
