Author Topic: Replaced my clutch plates, strange noise.........  (Read 1777 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: August 25, 2005, 10:34:04 PM »
I replaced my clutch plates about 500 miles ago. That was about two weeks ago before I took my bike on a 360 mile trip. I noticeed later during stop and go traffic, that a loud binding noise( like a growl) would come from my clutch cover. When I replaced the cork plates everything looked fine, no sloppy/worn parts. What do you guys think???????
Nomad.............
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Offline Lumbee
    • My pics...
Re: Replaced my clutch plates, strange noise.........
« Reply #1 on: August 26, 2005, 07:03:03 AM »
..what kinda bike???
"I'm not a welder, but I play one on HondaChopper.com"
  • 1976 CB550 K
Sorry it's 1976 Cb550K
« Reply #2 on: August 26, 2005, 08:32:23 AM »
It's a 1976 CB 550K.
Nomad...............
« Reply #3 on: August 26, 2005, 09:04:58 AM »
Did you soak the plates in oil before assembly?
I had a noise that I described as a "spooling" sound sometime after I replaced the clutch in my 74 CB550.
I remember thinking a bearing was going out, due to the vibration/chatter/growl under certain engagement conditions.
This was over 10 years ago.  I don't think I soaked the plates in oil before assembly then.
It went away after I re-adjusted the clutch actuating mechanism.  The noise never returned.
Maybe this was when I learned I was supposed to soak the plates first.  I have a fuzzy memory about clamping the clutch lever disengaged overnight, too.  Theory being that with the plates separated, oil would seep in and soak the plates in situ.
FWIW
