Author Topic: Long shot question regarding brake pedal spline....  (Read 2320 times)
Offline Canada
« on: June 08, 2008, 11:41:44 AM »
I bought some used Raask rearsets off of eBay that took 2 1/2 months to get here but that's another story all together. They were for a cb900f and I am going to use the pegs and linkages for my 78 cb750f3. It appears that the brake actuator spline is smaller for the newer cb900. I could probably make it work but I don't want to force it too much. Just wanted to pass it by you fellers before taking drastic measures into my own hands. I may just cut down my existing brake pedal and weld a bracket to make my own actuator. I see that some others have done the same.
Does clinching your teeth slow you down in the corners?
Offline kghost
Re: Long shot question regarding brake pedal spline....
« Reply #1 on: June 08, 2008, 11:49:51 AM »
Pictures?
Stranger in a strange land
Offline jonbuoy
    • My rebuild:
« Reply #2 on: June 09, 2008, 12:39:46 PM »
Yeah I braized a bracket onto mine, no problems so far.
Offline Geeto67
  • A grumpy
« Reply #3 on: June 09, 2008, 01:22:00 PM »
I have to ask the stupid obvious question here but.....why didn't you buy the raask rearsets for the SOHC cb750 F2/F3? They do make them you know....
You can order individual parts from raask....I forget if Omar's will do it for you but I know you can contact raask directly and tell them what pieces you want. A long time ago the pegs on my H1 raask rearsets cracked and I e-mailed raask and they sold me new pegs.
here is a pic of the raask f2 rearsets:
Omar's site:
http://www.rearsets.info/
Raask:
www.raask.com
Maintenance Matters Most
Offline Geeto67
  • A grumpy
« Reply #4 on: June 09, 2008, 01:25:34 PM »
also I don't know how you are going to get those 900F backing plates to fit since they have a different mounting system from the cb750F2/3 SOHC bikes...or did you make the fatal error and assume they are all the same?
these are the 900F rearset plates:
Offline Canada
« Reply #5 on: June 09, 2008, 10:51:21 PM »
I got them off of eBay UK really cheap. The brackets will not be used as I have another plan but the linkages will work perfect. I did contact Omar's but I confused them with what I was looking for and in the end the little metal actuator was going to be $75. LOL. Gimmie a break. I guess they are made of Platinum. I'm just going to weld a $.05 piece of iron to the existing brake pedal spline to make it work. All is good. I'll post pics once I'm done.
Offline Geeto67
  • A grumpy
« Reply #6 on: June 10, 2008, 08:29:50 AM »
If it will help I'll buy the parts you are not using off you....I own a 900F and could use those rearset brackets to make my own. Heck I might even be able to trade you for a set of generic mount tarozzi pegs.
YOu could contact jimhinshaw on ebay - he sells tarozzi rearsets and they have a similar splined brake arm for their cb750 rearsets and see what the part costs for him to get it for you.
welding a tab to you existing brake is going to be the cheapest option. The tooling to make splines is extremely expensive.
