Author Topic: Finally got wiring done. Explanation on how inside  (Read 837 times)
jay72chevy
« on: June 08, 2008, 03:40:48 PM »
Well with your help and PartsNmore harness I was able to figure out the running lights for the turn signals. My brother figured out the headlight, and didnt even need a jumper wire to go from the brown and red to brown and white.
The hardest thing next was figuring out why it was acting up even with the green ground wire for the front turn signals. I was using the jumper wire and grounded it off of the nut inside headlight bucket and ran the other side of jumper to a bolt on the bike and walla the turn signal lit up brite and the beeping sound chimed in.
Then I took the nut inside the headlight bucket out. I got wire stripped a long piece off and curled it up around the nut for the one side of signal, and tightened it for the headlight bucket. I did the same for the other side for the signal. I ran the wire back out the headlight bucket through the back. I crimped a circle fitting on the other side. I ran the wire down to the horn. I unfastened the two nuts that hold the horn on and put my wires to that and put the nut on the horn to hold the wires to the horn. Making a perfect ground for my turn signals. It does everything pefect now. Thanks everyone
