Author Topic: CB500 clutch woes  (Read 754 times)
Offline pdxPope
  • Hit Shit, Hat Shat, Hut Shut,
CB500 clutch woes
« on: June 09, 2008, 10:17:58 AM »
OK one of you CB500 gurus, I'm stuck.
I recently replaced the drive chain & both sprockets. So, being anal, I figured since I had her opened up a little I'd do some spring cleaning. So I disassembled the clutch pushrod actuating mechanism (the thing the clutch cable attaches to) cleaned & greased and reassembled.
Now I have no pressure at the lever, no clutch and no amount of adjusting will get me back to where it was (which was not great, but did at least work.)
I made sure the pushrod was all in one piece and the correct length. I replaced the little ball bearing that 'pushes' the pushrod. I even took the clutch cover off the other side to inspect and everything seems to be in order....
What do I do now? ??? ???
-JP
The flowers say "Let's go shopping together..."
While the unicorn whispers "...for adult toys."
