Author Topic: Max Rim and Tire size?  (Read 1292 times)
« on: June 09, 2008, 07:18:05 PM »
Hello:
I'm building my version of a Japanese Custom based on a CB750K2. I'm stuck on the rear wheel. I 've downsized the front to an 18" and want to take the rear to a 17". Does anyone know the widest rear rim that will squeeze in comfortably?
For example, I have a rolling frame (CB750F) with an Akront 3.00x18 and a 130/80-18 tire. That just barely clears the rr disk stay arm.
I thought I could use a 3.00x17, but no one seems to have it. Buchanan's has a 2.75 or a 3.5, but the 3.0s have been discontinued. The 2.75 is just a tad narrow to please me, but I'd hate to buy a 3.5 and then eat it. But a 3.5 would be kewl.
What are all these high powered Cafes running?
Thanks!
Offline hymodyne
Re: Max Rim and Tire size?
« Reply #1 on: June 09, 2008, 07:21:30 PM »
what you run on the rear may be determined by the rear brake stay. I've got a 120 on my bike and it just barely clears the brake stay. It also wears much faster in the center of the tire than it would if I were running a narrower tire...
many threads about tire size and selection here. check through what has already been discussed and you might (most likely) find your answer.
hym
« Reply #2 on: June 09, 2008, 07:31:32 PM »
hym
Thanks for the prompt reply. After seeing my CB750F (lack of) clearance, and reading your post I looked again at my setup and agree the rear brake stay appears to be a potential problem. Luckily I have a good welder on board and he can reposition that.
The wider rim, even a 2.75, would correct the profile of the 120 or 130 to make the wear more acceptable. I think the stock rim is a narrow 2.15.
I have been searching for "rim" and "tire" threads and will continue to do so. Nothing definitive yet.
More comments?
« Last Edit: June 09, 2008, 07:34:23 PM by MCRider1 »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: June 10, 2008, 08:18:39 AM »
I have a 3x18 alloy rim with a 130 tire on my 550 cafe and everyting is great.
If I were you I'd consider relocating the brake arm.
« Reply #4 on: June 10, 2008, 10:21:40 AM »
Thanks, was pretty sure the 3.00 would work, but held out for info on 3.5. EastCoastWheels.com told me they have sold 3.5 for CB750 with no negative feedback. Said if I bought it (Excel) and it didn't work they would exchange it for DID 3.00, so I bought the 3.5 with SS spokes. I'll lace it myself. Used to do it 30 years ago, so I'll have another whirl. Bought a truing/balancing stand off ebay for $130.
I'm expecting to move the brake stay.
