Author Topic: float keeps sticking  (Read 816 times)
Offline Scrubs
« on: June 10, 2008, 06:49:01 PM »
So I am a new owner of a K2 and very happy. One little problem I am having is one of the carb floats
keeps on getting stuck and consequently pissing petrol out of the overflow of the particular carb.
If I take the bowl off and on again and give it a quick fiddle all is well for a short while untill it happens again. They don't appear  gummy or anything. What do you suggest I should do?
Offline Gordon
  • 750K1, 550K2
Re: float keeps sticking
« Reply #1 on: June 10, 2008, 06:53:39 PM »
Pull the float hinge pin and clean/polish it up so the float can rotate smoothly on it.  You can also remove the float valve to make sure it's nice and clean.  If it still leaks, it may be time for new float valves.
Offline Johnie
« Reply #2 on: June 10, 2008, 06:58:20 PM »
And try to see if the floats may be rubbing on the inside of the bowl.  That can hang them up too.  Not sure what type floats you have there but my KO has the brass ones.  I could easily bend the tub in a little if it was rubbing on the sides.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Jv550
  • '75 CB 550 K
« Reply #3 on: June 10, 2008, 08:51:19 PM »
Can that be done with the carbs on the bike?
That's like hypnotizing chickens...
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: June 11, 2008, 02:47:43 AM »
It can be done, but it's definitely easier with the carbs off.
