Author Topic: Damn!— cb400f master cylinder questions  (Read 968 times)
Offline stay youth
« on: June 11, 2008, 10:08:04 PM »
I think I may screwed myself. I bought a master cylinder off ebay with a bore of 12.7. Now when I put it on my bike I cant seem to get it to pressurize. So I put on my old OEM leaky MC and it would apply pressure. I thought the stock bore was 10mm, is this correct? I doesn't seem like 2,7mm would cause it to not function. Any suggestions?
Thanks
1976 cb400f
Offline stay youth
Re: Damn!— cb400f master cylinder questions
« Reply #1 on: June 12, 2008, 12:46:29 PM »
It seems that a larger bore would creat more pressure, is this correct???
Thanks
1976 cb400f
« Reply #2 on: June 12, 2008, 01:37:10 PM »
No, bigger bore pushes more volume at lower pressure for the same piston stroke.
But, then there is the lever and where the fulcrum is compared to each other and the length of the lever to where your hand actuates it.  If there is a difference in mechanical advantage with these ratios, it is conceivable to get more volume AND pressure.
Offline TomC
« Reply #3 on: June 12, 2008, 05:57:13 PM »
Hi Stay Youth
     Stock CB400F1 master cylinder bore is 14mm.
          TomC in Ohio
Thanks
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline stay youth
« Reply #4 on: June 12, 2008, 10:42:49 PM »
Oh really?? SO maybe I'm not moving enough fluid through the system? Hmmm Any suggestions?
Thanks so much
1976 cb400f
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: June 12, 2008, 11:52:20 PM »
Sure the new MC is fully bled?  If there's any air pockets in there then when you squeeze the lever all you're doing is compressing that air, it acts like a little spring for all intents and purposes.  Bleeding a MC from fully dry can be difficult sometimes.
mystic_1
- John Augustus Shedd
Offline stay youth
« Reply #6 on: June 12, 2008, 11:56:51 PM »
Hmmm Well this is the first time I have ever installed a new MC. Do you have any tips for me?
Thanks so much!
1976 cb400f
Offline bozo4onion
« Reply #7 on: June 13, 2008, 06:14:17 AM »
What do you have against rebuilding the leaker. Not that hard. Made my 550F work as new. The kit is cheap too.
Offline stay youth
« Reply #8 on: June 13, 2008, 07:25:13 AM »
Mine old MC was horrible looking really scrapped up. I wanted something cleaner looking
1976 cb400f
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: June 13, 2008, 09:36:25 AM »
Thanks so much!
Go to the main forum page and type "bleed brakes" into the search box, lots of different tips and tricks about this on the site.
cheers
mystic_1
Offline bozo4onion
« Reply #10 on: June 13, 2008, 10:29:55 AM »
There are about several different ways to bleed the brakes from repeatedly short pumping the lever to bubble the air from the relief hole to sucking the air out by mouth with a long tube. I went to harbour freight and got a brake bleeder. This only worked in combination with some bubbling of the master cyl. Your search for "master cylinder bleeding" should help. BTW my bike had a Yamaha cylinder on it when I got it. It worked fine but it leaked. I got my Honda master from eBay for $20. Had to be rebuilt though. Good luck.
Offline stay youth
« Reply #11 on: June 13, 2008, 04:10:27 PM »
Thank you all so much!
1976 cb400f
Offline mystic_1
  • 1970 CB750K
« Reply #12 on: June 13, 2008, 10:05:00 PM »
Let us know how it goes.  :)
mystic_1
