Author Topic: Carb jet problem  (Read 877 times)
nollid51
Carb jet problem
« on: June 13, 2008, 12:40:46 PM »
Hey this is a quick question, although I searched and found no answers for it. I was cleaning my carbs and now putting them back together when I ran into a snag. One of my jets will not fit back in. everytime i out it back it simply falls out. I tried rebuilding another carb and it went together fine. I have keihin carbs for a cb550 1976. I've included a picture to show the problem, sorry for the cell pic.
*edit* picture isnt working ill try to fix it.
here is a link to the pic. it isnt embedding for some reason.
http://bp0.blogger.com/_goXteUMUcMk/SFLMc-HxjiI/AAAAAAAAAC8/QsjY9MtQLEo/s1600-h/061308_15221.jpg
im trying to show that it won;t stick. i dont know if that tube was misshaped when i pulled the jet out. I guesss my question is how do you fix this?
« Last Edit: June 13, 2008, 12:44:33 PM by nollid51 »
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Carb jet problem
« Reply #1 on: June 13, 2008, 12:47:18 PM »
Is the O-ring on the jet?  Hard to tell but I do not see an O-ring in the bottom slot.  This holds it initially and then the leaf spring, which is held in by the bowl, keeps the jet tight.
« Last Edit: June 13, 2008, 12:48:56 PM by kslrr »
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
« Reply #2 on: June 13, 2008, 12:52:31 PM »
The oring on the jet is there to create a seal, not retention.
There is a dual leaf spring that holds the main jet in place when the bowl is installed.  It's not in your picture.
nollid51
« Reply #3 on: June 13, 2008, 12:56:45 PM »
ok yes it is the o-ring jet. ok im glad to hear that the leaf spring will hold it. i was unsure b/c the other oring jets were difficult to remove and were snug when i replaced one on another carb. thanks guys for the speedy response.
« Reply #4 on: June 13, 2008, 01:04:02 PM »
Sounds like you need new orings.
Offline Dave-and-his-550
  • I know the pieces fit...
« Reply #5 on: June 13, 2008, 01:23:30 PM »
Was just gonna say that. Because the new o-rings will hold it in place as a matter of fact, but its not necessarily the job of the o-ring. If you aren't gonna place new o-rings on em', then just hold the carb upside down with the jet and leaf spring in their proper position and screw on the float bowl. It will hold the jet in just fine.
