Author Topic: l  (Read 960 times)
Offline c_packer
l
« on: June 14, 2008, 04:00:01 PM »
« Last Edit: June 15, 2008, 10:15:14 PM by c_packer »
I'm a creep, I'm a weirdo. What the hell am I doin' here? -Radiohead-
Offline tbpmusic
Re: I need a measurement from a cx500 swing arm.
« Reply #1 on: June 14, 2008, 04:21:07 PM »
I just did something similar with a CB450 - put on comstars from a 79 CB400T2.
The rear wheel was offset, like you're experiencing.
It was easy just to cut and grind some new spacers for the wheel. I used a level and a plumb bob, that's all you really need.
I lucked out, and when I centered it, the sprockets lined up nicely for me (that was a major concern of mine).
Worked out great, because I wanted to retain the 450 swingarm.
bill
Bill Lane
« Reply #2 on: June 14, 2008, 04:23:31 PM »
CX500 is shaft drive, you know.
Offline c_packer
« Reply #3 on: June 14, 2008, 04:46:02 PM »
No I did not know that!!
