Author Topic: Does any one give a Crap about my shop / garage build?  (Read 48719 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Does any one give a Crap about my shop / garage build?
« Reply #125 on: August 08, 2008, 06:33:33 PM »
My digital camera got wet last week helping a guy put his boat on a trailer........camera in shorts pocket. Using camera phone of carpenter.  This roof line is a long........haul..................
Offline heffay
« Reply #126 on: August 08, 2008, 06:50:25 PM »
nice first piece of sheathing!   ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #127 on: August 08, 2008, 06:55:00 PM »
Carpenter moved it around so he could work in the shade while building the dormer window frames ;D
Look where it shows up on the above photos through out the day. :)
Offline heffay
« Reply #128 on: August 08, 2008, 07:12:13 PM »
well, maybe someday it'll get nailed down.   ;) :D
upperlake04
« Reply #129 on: August 08, 2008, 08:16:47 PM »
  Nice shop Seaweb ;D
    I've used both wood and propane, vented and unvented, in my shops. The propane heaters do add a lot of water vapour to the air which made it clammy, were expensive to run and will continue to be so. The wood heaters put out a dry heat, a quality that might be appealing on those grey damp and drizzly BC winter days. I know the old timers in my neighborhood like to drop in and pull up a chair to the blazing stove on cold days.
   There are probably lots of locals with an old half-ton and a chainsaw that would cut, deliver and stack wood for a reasonable amount of cash if you don't want the job.   Kids can split wood too ;)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #130 on: August 08, 2008, 09:18:00 PM »
Fire wood is like gold around here. We all use it to heat our houses. I still don't have my stash for the upcoming winter ::)
My house has 2 wood stoves, the elect heat rarely gets turned on in the winter.  I just may end up going that way though. ;D
« Reply #131 on: August 08, 2008, 09:48:43 PM »
Seaweb, can you easily get building insurance for woodstove heating??..pretty tough around here,
 moreso for commercial purpose.. actually they will make you go running & screaming to get ANY other heatsource.. :(
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #132 on: August 08, 2008, 10:44:53 PM »
There is an inspection certificate you must get, but it's done all the time with houses here.    Fully insured ;D
Offline mark
« Reply #133 on: August 09, 2008, 08:04:43 AM »
As it appears that the floor has not been poured yet, how about laying down tubing(cable?) and doing a radiant heating setup?
http://www.thisoldhouse.com/toh/article/0,,1548320,00.html
A clever fellow might even figure out how to heat the water with a loop in one of the wood stoves??
Food for thought.........
F you mark...... F you.
Offline mrbreeze
  • Not your average
« Reply #134 on: August 10, 2008, 01:59:42 AM »
  Nice shop Seaweb ;D
Kids can split wood too...... ;D ;D ;D ;D ;D...oh hell yeah!!!!....ask me how I know!!! Wyoming 20 to 40 below zero....my boys helped me cut/split tons of firewood for the pad.
MEMBER # 257
troppo
« Reply #135 on: August 10, 2008, 02:10:51 AM »
I worked on a fridge boat for a while when i was younger, our hot water was heated by 5 loops of copper pipe wrapped around the exhaust pipe. If you have a jacketed flue on a wood heater you could run the pipe between the two layers, you wouldnt even see it that way
« Reply #136 on: August 10, 2008, 04:15:58 PM »
I agree with mark, investigate in floor radiant heat. I've got it on my shop and you can't beat it. A buddy of mine went this route as well in his 30x60' shop and heats the water with a tiny electric furnace, very efficient, especially since you're building new and can insulate well.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #137 on: August 10, 2008, 05:28:41 PM »
I am looking into the radiant floor heat, and chimney guy shoud be dropping in next week ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #138 on: August 14, 2008, 08:54:13 AM »
Ready for framing inspection ;D
Offline heffay
« Reply #139 on: August 14, 2008, 09:25:14 AM »
i dont think the tent will pass but the garage might  ;)
looks fantastic, although, at first, i thought the ladder was the post for that monster beam  :D
« Reply #140 on: August 14, 2008, 12:02:31 PM »
I'll be there next weekend and I promise you it will pass my inspection. I have your magazine packed too. Need anything else? I get home tomorrow night and head out Sat AM.
Online DME
« Reply #141 on: August 14, 2008, 12:07:40 PM »
Congrats on the build, Seaweb, it looks fantastic!
We all have different methods and build techniques, and yours seems to be very similar to our swedish methods.
One thing seems to differ though.
Over here the concrete slab would have been poured and completely finished with drains, hoses for underfloor heating, etc, before anything else was done.
The reason is twofold: 1. Easy access when pouring the slab with no walls or roof in the way, and 2. a nice work surface to continue the framing work on.
Is there a reason for saving the pouring of the slab until after the framing and roof is done?
Cheers and keep up the good work, can´t wait to see the finished product!
Dan
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #142 on: August 14, 2008, 01:11:59 PM »
Jerry, I don't need anything but a nap.
DME- The carpenter was ready to go.......so away we went.  I can pour the slab now even if its wet out ;D
Online DME
« Reply #143 on: August 14, 2008, 02:01:55 PM »
DME- The carpenter was ready to go.......so away we went.  ;D
That´s a very good reason  :D
Dan
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #144 on: August 18, 2008, 07:00:19 PM »
POWER!
Work bench goes under window ;D
Offline UnCrash
  • Pass
    • My Blog
« Reply #145 on: August 18, 2008, 07:21:20 PM »
Nice progress!
Offline DarkRider
« Reply #146 on: August 18, 2008, 08:17:52 PM »
Looking great Derek!
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #147 on: August 18, 2008, 08:43:52 PM »
WOW!!!!!  you have been busy while I've been on holiday....It's got a roof on :D :D :D :D :D :D
Are you going to sheet rock the inside ?
Sam. ;)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #148 on: August 19, 2008, 12:09:34 AM »
Sam. ;)
Just the walls, the lofted ceilings will be done in 4" tongue & grove pine, same as inside the house
........and yes that is a tree holding up the center of my house, 35 ft ;D
holidays?????????  Hope you had a good time.
martino1972
« Reply #149 on: August 19, 2008, 01:07:12 AM »
looks like you got a better paying job then i got,what do you do for a living??
