Author Topic: How many SOHCammers to change a light bulb..??  (Read 2005 times)
« on: June 15, 2008, 08:30:40 AM »
Well..a few..
one will come along and tell you how it used to be done back in the day..
there will be one who says it will work better with an add on module..
there will be quite a few, that will say it must be the newest most electronic mercury model or it will never be right!!
there will be a few that insist that it needs an o-ring on it.. :D
DONT even mention cost, there will be once that say it is only woth 2 1/2 cents, then someone will come along and say they are worth 3.75 cents, or maybe even 4 cents..  ;D
there will be a few that insist, that there is only 2 years of production that are worth having..
there will be someone comes along and asks, what is meant by incandescent bulb?
one will come along that has managed to scew up the threads on the base... :o.. anf one that has one stuck that they cannot get out.. ;D
 There will be at least one that has leaks, even though that is hard to imagine..
a few will want to make it brighter or better even though it is working fine
there will be at least one that bought the bulb used but NEVER gets it to work right...
 as you can see, it takes quite a few, & there is more...
 .. but its all good... ;D
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: How many SOHCammers to change a light bulb..??
« Reply #1 on: June 15, 2008, 08:34:55 AM »
Perfect!  So, is the incandescent lighting device ultimately used and enjoyed for what it is?  A light bulb?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline medic09
« Reply #2 on: June 18, 2008, 09:41:05 PM »
Which tool is best for changing it out?
Some will torque it; most will tell you only finger tight!
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
« Reply #3 on: June 18, 2008, 09:46:01 PM »
Are the threads dry, or lightly oiled..? :)
troppo
« Reply #4 on: June 19, 2008, 02:36:08 AM »
do you need to use lock tite or anti seize? ;)
eldar
« Reply #5 on: June 20, 2008, 08:47:58 AM »
Is the bulb synced with the other bulbs in the house?
Offline kghost
« Reply #6 on: June 20, 2008, 09:08:26 AM »
Don't forget the .....
"where can I buy a bulb"
"anyone have a spare bulb"
and last but not least .....
"are chen shin bulbs any good"
Stranger in a strange land
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: June 20, 2008, 09:15:32 AM »
What's the biggest bulb I can fit in my light socket?
Is it unsafe to use a 25 year old light bulb?
I'm thinking of buying a light bulb.  What problems should I be on the look-out for?
When I flip the switch, the light bulb does not turn on.  Is this normal?
« Reply #8 on: June 22, 2008, 10:12:32 AM »
Is it 110..or 220..(EUROspec)....??
If you end up not using your HIpo bulb, will you sell it & ship to Australia..
It has to be a Sylvania 44- 89, or at least a Sylvania 33- 69 to be able to work tight..
If you can find them the hand blown wide radius jobs out from J. A. Pan are the schiznitz... ;D
I am a minimalist, what can I strip off the light or shorten up??
A fellow comes along and tricks up the bulbs nicely, the crowning touch is a checkered pattern across the bulb!! His bulbs sell for 66.6% more than all the others...
And everyone ends up hating the guy... ;)
altf4
« Reply #9 on: June 23, 2008, 11:29:51 AM »
Simple answer.
One to tell the poster to check the FAQ.
My thoughts exactly!  :D
Offline DarkRider
« Reply #10 on: June 25, 2008, 04:11:20 AM »
and one to remind ya that this is a.......REPOST!
http://forums.sohc4.net/index.php?topic=33818.0
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #11 on: June 25, 2008, 05:49:59 AM »
None.. the bulb is fine..
But the owner has to take it out & dick with it anyway BECAUSE it is working fine..
Question, my bulb is fine at 110 volts, but would it not be so much better if it ran at 125volts   ???
« Reply #12 on: June 26, 2008, 08:01:17 PM »
Sorry guys. i rarlely ever venture into the humor side..
 looks like we got new responses tho...
Offline ieism
« Reply #13 on: July 03, 2008, 11:13:41 AM »
Oh no, not another oil tread.... :D
---cb550---
Offline firecracker
  • At being Shameless, I'm an
« Reply #14 on: July 03, 2008, 11:55:44 AM »
Which oil thread should I read to determine which oil to use?
 ;D
Life is like a game of cards.  The hand you are dealt represents determinism.  The way you play it is free will.
  -  Jawaharal Nehru
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: July 03, 2008, 03:40:46 PM »
 ;D
That's an easy one...
None of them!
No one has ever been any smarter or come away with any concrete, helpful information after reading any of the oil threads that have existed throughout history.  Their sole existence is for entertainment value only! ;D
In fact, any post title that includes the words "which oil" or "synthetic" should automatically be put in the Humor section. :D
« Reply #16 on: July 03, 2008, 03:59:53 PM »
LMAO  i just spit beer on my keyboard a little
Offline DarkRider
« Reply #17 on: July 05, 2008, 12:51:26 AM »
are any korean bulbs good?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
