Author Topic: K and F carbs  (Read 708 times)
Offline eastoak
K and F carbs
« on: June 16, 2008, 05:08:17 PM »
i did a search and came up with some replies but not as pertains to carbs. will a '75F carb work on a '75K bike? or the good deal i got on a set of carbs not such a good deal after all ???
Offline mystic_1
  • 1970 CB750K
Re: K and F carbs
« Reply #1 on: June 16, 2008, 05:21:19 PM »
It would seem so.  I just recently discovered that the carbs on my 1970 K0 are actually from a 1975 F.  (casting 064A)
You should re-jet the carbs to the appropriate settings for your engine (check the tech library for specs).
mystic_1
- John Augustus Shedd
Offline cleveland
Re: K and F carbs
« Reply #2 on: June 16, 2008, 05:24:05 PM »
I believe the only difference is the jets.
Offline eastoak
Re: K and F carbs
« Reply #3 on: June 16, 2008, 05:26:38 PM »
thanks for the replies. i suspected that they would work but it's nice to hear it from someone else.
