Author Topic: ...must be rant night.....so  (Read 1080 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« on: June 17, 2008, 07:30:54 PM »
begin rant
Does any state regulate the maximum height headlights can be above the ground? On the way home tonight...on the bike...I was followed way to closely by one of those swamp trucks whose headlights had to be 5 to 6 feet up.  It was like having two carbon arcs pointed at the bike. How can you possibly take headlights that were designed to be mounted a couple feet off the ground and adjust them so they provide the correct beam pattern for the driver without blinding everyone else? I'm not sure if he had on hi or low beam, but hi beam would have probably gone over my head and been better.  >:(
I finally just pulled over and let him go!
/end rant
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: ...must be rant night.....so
« Reply #1 on: June 17, 2008, 07:41:50 PM »
All you have to remember when you see a raised truck is that the driver probably has a sub-par intellect to go with his small penis. Give them lots of space, thereby massaging their ego-in-need-of-help, and make life easier for yourself.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline UnCrash
  • Pass
    • My Blog
« Reply #2 on: June 17, 2008, 07:42:26 PM »
You're better off just letting them go anyway.
- agreed it is annoying.
I've done the same thing.  As they pass I take out my imaginary paint ball gun and give their vehicle an imaginary dousing of bright orange.
Offline nickjtc
« Reply #3 on: June 17, 2008, 07:49:01 PM »
PS To answer your question, there almost certainly is a regulation governing the height that headlights may be above the ground. However, if they are no higher than those that may be found on a semi they are probably within the law.....if they are adjusted correctly.
1977 Suzuki GS750
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #4 on: June 17, 2008, 07:56:19 PM »
1/2 the beaters here only have one light working anyway ;D
Offline DarkRider
« Reply #6 on: June 18, 2008, 01:46:57 AM »
I cant understand why some people lift their trucks to the heights they do....basicly anything over a 6" lift is overkill...even 6" borders on it...I will be lifting my new blazer sometime soon but i wont be going over 4" with it and thats with a combined suspension and body lift..
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline nickjtc
« Reply #7 on: June 18, 2008, 07:25:50 AM »
Try looking cool, as a driver examiner, when you attempt to get into one of those things without a ladder...
1977 Suzuki GS750
eldar
« Reply #8 on: June 18, 2008, 08:48:54 AM »
A lot of those lights are not actually street legal. For "off road use only". So more than likely, he is breaking the law in the first place.
