Author Topic: Kickstand ?  (Read 588 times)
Offline greenjeans
  • 1972 CB750K2
Kickstand ?
« on: June 18, 2008, 12:09:22 PM »
72 Cb750K
Just how far are these thing supposed to lean over on the kickstand ?  Is it possible that I have the wrong kick stand on this thing ?
I can put a 2x4 and another 3/4" piece of plywood under mine and it still leans....
Just seems TOOO far over, so much that I never use it.  I usually just use the engine stand...bit of a pain.
Re: Kickstand ?
« Reply #1 on: June 18, 2008, 12:11:45 PM »
Yep mine does the same - both the K2 and the K4. Ive tried different kickstand for these years and they are all the same. I also use the wood to keep it up more. You can probably bend the foot of the stand so that it sits more upright.
cheers
Andy
Offline mcpuffett
Re: Kickstand ?
« Reply #2 on: June 18, 2008, 12:30:43 PM »
your stand looks as though it is bent in the photo it should be pointing more towards the floor rather than straight out  :o, as Andy suggested you could try bending it back into shape, cheers Mick.
