Author Topic: 1975 Honda CB125s - Possible Electrical Problem  (Read 2010 times)
chriscraft42
« on: June 18, 2008, 01:36:52 PM »
I am having a strange issue with my 1975 Honda CB125s signal lights. The right and left signal lights (front and back work until I put the headlight on and then they stop working. Does anyone have any suggestions to correct this problem?. All other electrical on the bike works just fine...thanks
« Last Edit: June 19, 2008, 05:16:36 AM by chriscraft42 »
Offline 333
  • Time for change
Re: 1975 Honda CB125s - Possible Electrical Problem
« Reply #1 on: June 18, 2008, 01:51:42 PM »
Do you have a multi meter?  What is the volts reading at the battery with;
1. engine off
2. engine only on, at idle.
3. engine only on, at about 2,000 rpm
4.  #2 and 3 with headlight on
If the battery reads below specified voltage with #1, it probably needs replacing.  If it is bad, it probably is drawing too much from the charging system to run everything.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: June 18, 2008, 05:17:02 PM »
Blinker mechanisms get old. The older the get, the more resistance they have. With the headlight on, there just may not be enough current to overcome the increased resistance of the old blinker.
There are a number of 'electronic' blinkers that you can buy for 7-12 bucks at places like schucks, autozone, etc.
They do not use the resistance to blink, and will blink with whatever current they are getting.
Give one a try.
No.
Offline 333
  • Time for change
« Reply #3 on: June 18, 2008, 07:28:52 PM »
Mlinders idea is a good one except for one thing.  I don't think they make those for 6 volt systems.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #4 on: June 19, 2008, 10:29:19 AM »
Yer probably right.
Have to pick up a honda part, then.
No.
Offline kirkn
« Reply #5 on: June 19, 2008, 06:01:46 PM »
Well, no, not necessarily a HONDA part.
I'll agree that the first likelihood is a new blinker relay.  However, a decent automotive store (not really Discount Auto Parts, or PepBoys, etc) should be able to get you one.  After all, there WERE 6-volt autos, although quite a while ago now.  Probably cheaper than Honda, too.  Or even ebay, or the internet, generally.
Has it REALLY been 40 years since 6-volt VW's?
