Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 890411 times)
Offline Tintop
Re: Phaedrus II: CB750 "Super Standard"-Update 05/23/13 w/ new pics
« Reply #2825 on: May 24, 2013, 05:18:42 AM »
Brown's may go out of business when you finish this project, you've got to be one of their top customers. ;D ;D ;D ;D ;D
I know you're just kidding, I'm just another job to them. Its actually been nearly 2 years since I sent them anything. But what the hay?   :D  I do have the T shirt.
Is it chrome?? ;D ;D ;D ;D ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #2826 on: May 24, 2013, 05:20:28 AM »
Clocks and machined parts look great. So it will be 888cc?
Thannks.
Yeah, that's been the size all along. Phaedrus I was a 888cc Powroll kit. Ran wonderfully for 50,000+ miles. 67mm= 888.8cc Too big for stock sleeves.
So I replaced that with 888cc pistons from ARIAS, much nicer slugs.
« Last Edit: May 24, 2013, 05:50:01 AM by MCRider »
Offline brandEn
« Reply #2827 on: May 24, 2013, 08:17:20 AM »
Wow Ron, that engine is gonna scream. Nice, I can't wait to see you put it back together.
« Reply #2828 on: May 24, 2013, 09:01:24 AM »
I've been silently hoping for 80hp (mild cam) just to put a number on it. Mike says the OS intakes are good for 6-8 hp, so that'll push me closer to that goal nicely.
« Reply #2829 on: May 24, 2013, 09:04:19 AM »
Ron,
Looks like you have the reliefs/angles cut on the bottom of the cylinders in the block. I used o-rings from a CB900 for mine to help insure sealing.
No reason you shouldn't get 80hp. I think you'll be pleasantly surprised  ;)
« Reply #2830 on: May 24, 2013, 09:11:01 AM »
Ron,
Yeah, looks that way to me too. Prior cyls lost them. Got by without but I'll definitely use them and was wondering where/what ORings to use. The CB900 tip should work, I'll order a set. I'll talk to Mike first, wasn't expecting they would be recut.
My FJR had a lot more, my HawkGT has a lot less, enjoy(ed) them both. 80hp; 60 lbft torque seems to be a sweet spot for a real nice ride.
« Reply #2831 on: May 24, 2013, 12:59:26 PM »
Ron,
Those "reliefs" are the product of the taper sleeves....nothing was recut. The original sleeves were straight wall (like the sleeves in my 915 engine) thus no gap after boring the cylinder. I will be sealing those with 1194 to prevent oil creep. The cylinders "windowed" on 1/2 and 3/4 but that happens 99% of the time. the cylinder will be painted and I don't think Ron will be riding the bike through extended rain storms. It will all work out fine....it's all under control gentlemen. ;) ;D
« Reply #2832 on: May 24, 2013, 01:43:15 PM »
Had I known they were still in The Man's hands.....  Thought Ron had them.
« Reply #2833 on: May 24, 2013, 04:02:08 PM »
What a work of industrial art. My head just got delivered to Mike today for some TLC.
« Reply #2834 on: May 24, 2013, 04:07:07 PM »
Ok....that explains the package. I've was setting up a new Weber for the weekend etc.....haven't had a chance to open the box!
« Reply #2835 on: May 24, 2013, 04:32:16 PM »
Since when are you allowed to eat? Get to WORK!!
jk, have a great weekend.
« Reply #2836 on: May 24, 2013, 04:33:16 PM »
No, those pictures wre just to tease me. Taken at Mike's place.
« Reply #2837 on: May 25, 2013, 03:40:52 PM »
Painting the head and cylinder tomorrow....weather here has sucked with constant light rain for 36 hours. I like to paint outdoors as it stinks up the house even though I'm in the basement. Filled voids where the cam cover meets the the head....small stuff (actually one was big) but it makes a difference. ;) Detail stuff does make a difference.
« Reply #2838 on: May 26, 2013, 06:56:40 AM »
Understood. Do what you need to do. I'm keeping busy with other things.
« Reply #2839 on: May 27, 2013, 12:17:08 PM »
Something tells me that Mike has plenty to keep him busy!  ;D
« Reply #2840 on: May 27, 2013, 04:22:12 PM »
Finally got a box of odds and ends for Brown's. Had to find a box the centerstand would fit in.
Took the kickstarter apart, hope I can get it back together. Its in the box for rechroming.
Been experimenting with various heat shrink tubing on some old instruments. The shiny black housing on the pigtail dries and and cracks. I bot some gloss black heat shrink from eBay hope it works on the speedo.
The tach is a never used brand new item. But the pig tail had been coiled around the tach and there it sat in a box for 30+ years getting hard in that shape. Now its time to use it and I'm afraid to straighten it out as it might crack. I soaked it in some Rubber Renew for a few days, then applied a hairdryer heat to it for a few minutes. It softened right up and laid out straight.  The RR may not have been necessary, I think the heat did all the work. But the RR is good longer term I'm sure.
« Last Edit: May 27, 2013, 04:23:57 PM by MCRider »
« Reply #2841 on: May 27, 2013, 07:00:57 PM »
Update: the pigtail on the tach straightened easliy when heated. But when it cooled it hardened again, maybe harder than before. But at least its going where I want it to go.
« Reply #2842 on: May 27, 2013, 07:01:31 PM »
It's all done. Fitted the rings today...Holy S.....I have never had to take material off the the oil rails until today. And I mean  a lot. Lots to take off off of the top rings too. Parts look mint.
« Reply #2843 on: May 29, 2013, 05:16:40 AM »
Thanks Mike. Let me know of any doo dads I need to buy. I bought 8 new piston circlips locally 15mm JIC.
« Reply #2844 on: May 29, 2013, 11:00:09 AM »
Were the rings of a different brand, for the 67mm size? Resulting in the unexpected oversizing. I guess its SOP to check for that, but usually not much sizing is required?
Were the original cylinders "windowed"? I never knew one way or t'other.
« Reply #2845 on: May 31, 2013, 05:05:33 AM »
The rings are from Total Seal. They are generally oversize a bit which is a good thing as you can get the gap you want. The oil rails had about .003 to .004.......you need .015 minimum.
 I'll have to check the old cylinder but like I said it happens most of the time.
« Reply #2846 on: May 31, 2013, 05:11:26 AM »
Thanks Mike, just curious. Getting ready to receive...  ;D
« Reply #2847 on: May 31, 2013, 05:16:09 AM »
Working on the pigtails to the instruments, mainly the speedo. The gloss black outer covering is cracked in several places. The obvious fix is heat shrink tubing. But the problem has been in getting the right size in plain gloss black. Lots of dull black, and gloss black with lettering.
So I found a 9' piece on eBay but its 1/2 in which on the face seems too big. I bot it anyway. With a heat gun, it shrank up tight on the 5 wire bundle of the speedo. ITs not quite as glossy as OEM but close enough. I didn't shrink it real tight allowing the wires to flex. But if final experiments prove out I'll have some excess to sell.
« Reply #2848 on: May 31, 2013, 07:58:14 AM »
This place has good sleeving Ron  http://vintageconnections.com/
Offline Jayhawk
« Reply #2849 on: May 31, 2013, 12:05:22 PM »
They're an excellent source of Honda electrical connectors as well; I have one of the crimpers Vintage Connections offers, and it's the business.
