Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 876115 times)
Re: Phaedrus:CB750 RestoMod-Another 3rd Pl 9/20/14 and some real miles 9/21/14
« Reply #3450 on: September 29, 2014, 05:08:25 AM »
Puled the oil pan to inspect pump screen. Couldn't really get it off, pipe in way. But was able to drop it to where I could see the screen and rub my fingers over it and in the pan.
A little fluff in screen, assumed to be from prior clutch plates which seemed to have melted down.  There was a lot of fluff in screen when checked previously. Now just a slight amount with more miles than before. Situation deemed OK.  Inspected oil filter and cover, All OK.
Next, we need more mileage. Hopefully this weekend, 50-100 or so.
Offline grcamna2
« Reply #3451 on: September 29, 2014, 06:14:02 AM »
I hope you get some nice Break-in miles on her Ron so all those new parts get well seated-in, maybe a few 100...
« Reply #3452 on: September 30, 2014, 12:17:41 PM »
Tentative schedule is for more miles this weekend. Then maybe the drags OCt 8, or 15.
Just ordered a 17t sprocket. Currently geared 18/48. Mike tells me that may be a little high even with the 17" rear wheel. Not going for absolute best time. But a good time for a streetbike.
Offline grcamna2
« Reply #3453 on: September 30, 2014, 01:40:25 PM »
How's the clutch feel to you ?  :)
« Reply #3454 on: September 30, 2014, 02:17:16 PM »
The lever feel is very firm, but progressive.
But actually underway, I don't know. Rick said it may get to be a handful in traffic, but just riding , it was OK.
It doesn't slip, that's the main thing.   :D
« Reply #3455 on: October 02, 2014, 01:41:58 PM »
I'm sorting pics for different posts. Thought I'd throw this in. "No pics, it didn't happen".
« Reply #3456 on: October 05, 2014, 07:57:13 AM »
There have been some threads about spin on oil filters. I was interested in one as well. But the number of testimonials as to poor quality, leaks etc turne me off. I settled for a turned down unit from Carpy. It has all the fins turned off and then grooves turned in. To match the other grooved items of his that I have. Like the grooved rear axle spacer, and the grooved brake stay.
Anyway, by turning off the locating lug, we have 2 worlds. A high quality spin on. A standard oil filter which needs a wrench to cinch it up and loosen it.  Once its spun on, just hold it still to line up the front fins to vertical, hit it with a quarter turn on the wrench and done.
Not the best picture to show what I mean. Ill post a different view if anyone cares.
« Reply #3457 on: October 05, 2014, 08:20:07 AM »
Prepping for Drag Strip:
http://forums.sohc4.net/index.php?topic=141770.new#new
Mike said get the gearing down, so I ordered a 17t sprocket. 48t rear and 17" rear wheel, /70 tire.
I think my bettery is fired. We abused it, discharged it a few times and never treated it fairlly. Now that the electrics are sorted, I ordered an AGM Scorpion.
The best, early, CB750 stock turned 12.9. I'd be happy starting there and getting into the 11s.
No mileage this weekend, rider called in sick. Taking it to Saldanas for a new chainguard. The original one was too flimsy to pass tech inspection, and to street for that matter. MAy change the design as one with a curved rear will not allow for chain adjusting. A straight blade with small sides may be better.
Offline grcamna2
« Reply #3458 on: October 05, 2014, 08:26:26 AM »
What's the front side look like ?
« Reply #3459 on: October 05, 2014, 06:22:36 PM »
Here tis: L & R
You can see the locator lug is gone so you can spin what's left all the way to the ORing. Set the front vanes to vertical, horizontal or wherever, hit it with a wrenc for 1/4 to 1/2 turn and be done.
Re: Phaedrus:CB750 RestoMod-Prepping for drags: 10/5/14
« Reply #3460 on: October 05, 2014, 06:30:01 PM »
Update: Delay on making chainguard till Wednesday. Gives me time to sketch up oil cooler mount as well.
Offline grcamna2
« Reply #3461 on: October 05, 2014, 07:56:27 PM »
That's a nice oil filter housing. I love that new title Ron "prepping for drags"  ;D  8)  ;)
« Last Edit: October 06, 2014, 06:48:45 AM by MCRider »
« Reply #3462 on: October 06, 2014, 06:48:59 AM »
Thanks, I bot the filter housing second hand from a forum member, I think Carpy's current one loks different, maybe not.
I try to keep the title current with what's going on this week or so. May not make the drags this year, only one more day possible before they close for the winter. Then it wiill be Apriil and we'd be ready.
« Reply #3463 on: October 06, 2014, 09:34:19 AM »
Oh yeah, after al the cold starts with choke, and the sloppy on off miles, I finally pulled a plug for curiosity sake. It was a nice creamy tan color, dry. We haven't got to redline yet, but it sure feels fine.  :D
Offline grcamna2
« Reply #3464 on: October 06, 2014, 10:56:12 AM »
is next weekend the last one for the drags this year ?
« Reply #3465 on: October 06, 2014, 11:10:50 AM »
The local night is Wednesday. The 8th we'll miss cause I don't have enough miles on it. Weather permits, next weekend, we'll continue break in. Wednesday the 15th is our target. The final date is Wednesday the 22nd. But I'll be out of town with wifer on R&R. So, the 15th is it.
Offline grcamna2
« Reply #3466 on: October 06, 2014, 01:43:34 PM »
Will Mike be the drag racer for you next weekend ?  :)
« Reply #3467 on: October 06, 2014, 01:51:09 PM »
That would be great, but I don't have the travel budget.   :D
My local friend Rick Dorfmeyer has hundreds of roadrace starts under his belt, and he said he'd give it a go. No actual drag strip experience, but not afraid to get on it.
Offline MiGhost
  • What was that about being an
« Reply #3468 on: October 06, 2014, 02:17:13 PM »
Just be sure to remind your rider that there is no turn at the end of the straight away. Not until the end of the track anyways. ;D
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
« Reply #3469 on: October 06, 2014, 03:23:22 PM »
Yeah I think he remembers. He and I roadraced there back in the 70s. When it was Indpls Raceway Park and WERA raced there.  In some of my pictures you can see where the last turn from the road course merges in to the dragstrip, on the other side, that doubles as the straightaway for the road course. At the end you turn left to exit the drags, turn right to continue the road course.
I'll remind him.   ;)
« Reply #3470 on: October 08, 2014, 11:44:39 AM »
Got the new chainguard from Saldana, looking good. I asked for one like FunJimmy's, which is really sweet. He said sure, but what I got had been personalized to where it doesn't look like FJs. But the business end is flat and long. Pic coming.  Thicker material. Good for tech inspection at the drag strip, this year or next.
Fine with me. Can't be too picky about design when you've got someone working for you that can do it.
Reworked the muffler/centerstand stop brckt.
Worked up the oil cooler brckt.
« Last Edit: October 08, 2014, 11:47:05 AM by MCRider »
« Reply #3471 on: October 09, 2014, 05:59:20 AM »
What I wanted out of a chainguard was: 1. a modest profile, as though it weren't here, 2. coverage for oil fling off, 3. ability to adjust chain, and 4. enough beef to satisfy the tech inspectors at the strip. The first guard I had satisfied 1 and 2, but failed at 3 and 4. When you have any amount of curve to the tail of the guard, following the sprocket, its going to hinder adjustment.
This ought to do it: made from 1 single piece, cut and bent.
By putting the strengthening bendover on the inside, the profile stays minimal:
The material is about twice as thick as the first one, and with the bend, the length of the blade, its plenty strong.
I'll send it out for polish or chrome later.
So many cafe's / resto-mods are "finished" without a guard, seems like an oversight to me. I don't like chainlube on my gear. Carpy's guard he sells now (fits K2 and up), the blade isn't as wide as the chain, allowing for sneakby. Could be because if it were wider than the chain, and you use a shock with a full length spring, you have to notch the guard to clear the spring. This immediately introduces a weak spot in the guard which will break over time. So he shortcutted it and made it too narrow to be effective.
Mine is notched for the spring clearance and the bendover runs the full length of the blade, reinforcing the area across from the notch.
« Last Edit: October 09, 2014, 06:18:33 AM by MCRider »
Offline grcamna2
« Reply #3472 on: October 09, 2014, 07:01:17 AM »
I love those chrome stands and swingarm Ron  ;D 8) 8) 8) I know it'll make cleaning a Lot easier.
« Reply #3473 on: October 09, 2014, 07:59:04 AM »
You're looking at the world's most expensive centerstand and side stand, jointly and severally. They are clean however.  ;)
« Reply #3474 on: October 09, 2014, 08:04:06 AM »
You're a patient and meticulous caretaker Ron and I salute you. I subbed out most of my chrome, black chrome and polished bits for powdercoat when I last rebuilt my bike to make cleaning easier after riding.
