Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 876626 times)
Re: Phaedrus: CB750 RestoMod - Update: New Pics: 19/30/18
« Reply #4375 on: October 15, 2018, 08:36:20 PM »
Tell us more about the Ti bolts please..
« Reply #4376 on: October 16, 2018, 06:08:02 AM »
CBJoe gave me the link, which is in the post of a few ago. I've never dealt with them. I've read up on their operation. They manufacture out of the UK, and ship out of somewhere in FL. They seem to be worldwide. The pricing is on each product description. Colors are more.
But they are crazy cool in that they are pre drilled for safety wire. All shapes and sizes. Hope to get my order in this week. They are evidently big on drilled sprocket nuts. But a nut is a nut and you get your size and pitch and order.
I've found places that drill bolts, but none other that drill nuts. I tried to drill a few with a small drill press and jig, and failed miserable. Bit breaks with the slightest pressure.
« Reply #4377 on: October 28, 2018, 03:45:43 PM »
Bruce and I were having trouble getting our head's wrapped around the cam degreeing process. We'ld done it years ago with a 41 grind. Now we're doing a CycleX C7 cam which is similar to a something or other big lump cam.
Build Buddy Joe (CBJoe) brought his dial indicator kit over. It appears to be like mine but like 15-20% more beef. We were able to get real good readings off of it, and I think we have it. We'll get some third party confirm, then move along.
Pics, etc to follow. Just glad to have that out of the way. On to better things.   :D
Re: Phaedrus: CB750 RestoMod - Update: No New Pics Yet: 10/29/18
« Reply #4378 on: October 28, 2018, 04:47:34 PM »
Ron, I'm waiting on those dyno numbers you didn't get to before that you should have  ;) ;D
« Reply #4379 on: October 28, 2018, 05:03:23 PM »
Me too! WE're working on it.   :D
Offline CBJoe
« Reply #4380 on: November 04, 2018, 01:00:43 PM »
Top end All buttoned up....soon Jerry ;)
Here’s the evidence
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #4381 on: November 11, 2018, 04:09:57 PM »
Soon.....finish exhaust and mount carbs next week   Who knows Ron...maybe Phaedrus will purr before long
« Last Edit: November 11, 2018, 04:12:16 PM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
« Reply #4382 on: November 12, 2018, 06:16:42 AM »
I'm thinking Ron is in for a big surprise  ;)
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
« Reply #4383 on: November 12, 2018, 10:36:10 AM »
Hope she doesn't melt when she gets out in the sunshine. ;D
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Offline CBJoe
« Reply #4384 on: December 02, 2018, 09:36:09 AM »
Exhaust - CHECK
Carbs - CHECK
Fuel and Fire next week!
'65 CB77
'66 CM91 (C90'ish)
Online MRieck
« Reply #4385 on: December 02, 2018, 10:50:11 AM »
 Looking good fellas. ;)
« Reply #4386 on: December 02, 2018, 02:44:45 PM »
« Reply #4387 on: December 02, 2018, 05:29:29 PM »
Thanks. And thanks as always to Build Buddy Bruce and CBJoe. Without them I'm afraid I'd be dead... in the water.  ;)
Update coming soon.
« Reply #4388 on: December 10, 2018, 11:46:58 AM »
It started easily, did not smoke, but doesn't seem to be running on all 4. We can fix that.  Pipes sound Gooood!
« Reply #4389 on: December 10, 2018, 12:38:56 PM »
« Reply #4390 on: December 10, 2018, 08:12:10 PM »
thanks for the update Ron....hope you are staying warm in the shop and house.... Glad to hear she's alive again.
Offline CBJoe
« Reply #4391 on: December 16, 2018, 08:50:13 AM »
Here’s the first start last week....missing on 1 and 4
Pulled the Smoothbores to to check and adjusted the float heights.  Then found a few things wrong :)
All corrected and what do you know...It’s Alive!
« Last Edit: December 16, 2018, 10:17:23 AM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
« Reply #4392 on: December 16, 2018, 10:01:12 AM »
YAY! More stills and explanation later.   ;D   ;D   ;D   ;D
Those blips were with a semicold motor, partial choke (dummy), gas turned off (dummyx2) and only about 5K.
Turn the volume on your computer up to get the bass of the exhaust note.
« Last Edit: December 16, 2018, 12:18:20 PM by MCRider »
Re: Phaedrus: CB750 RestoMod - Update: Video! 12/20/18
« Reply #4393 on: December 16, 2018, 10:18:27 AM »
Sounds big Ron
Offline Tintop
« Reply #4394 on: December 16, 2018, 11:41:25 AM »
Sounds and looks great Ron. 8) 8)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #4395 on: December 16, 2018, 12:25:11 PM »
Way to go Ron and Joe!!  That smile is priceless Ron, worth the price of admission. Kudos to you Joe for assisting in this adventure. Ron, where is your other build/tinkering in the garage buddy?
« Reply #4396 on: December 16, 2018, 12:53:35 PM »
Build Buddy Bruce is still with us, every day that I'm in the shop so is he.
Joe injected some enthusiasm and a different set of eyes that was sorely needed, and big thanks goes to Bruce and Joe. While this was a milestone, we'll be whiddling away on this project for a while. Joe has been drafted for break in duties, and we gotta get a good dyno run. Then we'll see whats next.
PS: Because of my Parkinson's it takes an effort to get a smile out of me, but that did it.   ;D
« Last Edit: December 16, 2018, 01:10:08 PM by MCRider »
Re: Phaedrus: CB750 RestoMod - Update: Stills, Video! 12/20/18
« Reply #4397 on: December 18, 2018, 09:17:36 AM »
In the second vid we can see that the #1 slide had become disconnected from the actuating bar. None of us have any idea how that could have happened. The set bolt was in a tray I keep on the workbench for misc bolts. It would have required removing the cap, held by 3 screws. Once threaded in, number 1 was synchronized with 2,3,4, working as it should. That would explain why the last dyno run was 2/3 of what I expected. It would also explain why the compression was so low. It wasn't getting any air to compress!
Man, that will go down as a mystery of the ages. I'm thinking it had to do when I was prepping to send them out for cleaning, then decided not to. Just spec, I have no memory of removing it.
I almost didn't post this,as it is way embarrassing. But, that's one of the privileges of old age, no shame.   :(
Offline Phoenix
« Reply #4398 on: December 18, 2018, 10:40:53 AM »
Sounds great Ron in spite of the circumstances.  Should get a neat dyno run.  God predetermines one f/u per rebuild.  Nice to get that out of the way.  Nice work guys.
Ed
Ed Spengeman
Indy
« Reply #4399 on: December 18, 2018, 11:14:05 AM »
Ed
Thanks Ed!
One f/u?  Yeah that's what we'll go with, 1 f/u.   ;)
