Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 1245299 times)
Re: Phaedrus: CB750 RestoMod - Update: 9/19/19 w/new pics- DYNO run
« Reply #4500 on: October 02, 2019, 01:15:54 PM »
It shouldn't be a problem Ron. I have synched other smoothborr and flatslides....they all require the tops off
« Reply #4501 on: October 02, 2019, 03:53:06 PM »
Ron I will explain/show Joe what we are talking about this weekend.
Mike do you have a link to the brass "fittings" and rubber caps?
« Reply #4502 on: October 02, 2019, 05:04:28 PM »
I think Joe went to Berber.   ???
Offline CBJoe
« Reply #4503 on: October 02, 2019, 05:42:16 PM »
Hey Ron...I'm meeting Jerry down at the Barber Vintage Festival this weekend  ;)
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #4504 on: October 02, 2019, 07:38:34 PM »
 ;) All good boys. See you Friday. I should roll in noonish maybe.
Offline CBJoe
« Reply #4505 on: October 27, 2019, 10:29:18 AM »
Somebody likes their new lift table
Hell, I liked it enough to buy one myself The Handy Lifts are super nice and lifted my guzzi with ease.
'65 CB77
'66 CM91 (C90'ish)
« Reply #4506 on: October 28, 2019, 06:47:35 AM »
How expensive are those lifts with accessories needed to be able to work safely and which model of lift did you guys buy? Looked on the website but couldn't figure out which was best and was it something like $1500 retail?   Did you buy direct or from an online seller?  Thank?  Does it take much volume of air to run, I only have a small pancake compressor with 3 gallon tank...
Offline CBJoe
« Reply #4507 on: October 28, 2019, 03:15:01 PM »
Hey David...I'll email you some details.  This nice review answers your other questions
'65 CB77
'66 CM91 (C90'ish)
« Reply #4508 on: October 29, 2019, 05:56:55 AM »
 A very nice lift. I really like the automatic safety catch and the drop plate at the rear. Those air bellows look like a very good idea as well....less complexity with no reduction in reliability.
 Good luck with the lift Ron.....us old guys deserve a good lift. ;D
« Reply #4509 on: October 29, 2019, 10:31:40 AM »
Handy lifts are pretty bulletproof. If you ever see one on craigslist for a decent price, do not hesitate to grab your truck.
« Reply #4510 on: October 29, 2019, 11:08:27 AM »
I totally agree.....my Model 1000 is still strong after close to 25 years. They are beasts. ;D
« Reply #4511 on: October 30, 2019, 06:42:37 AM »
Us old guys... sigh.   :)
Many new features. As you mentioned. Plus 6 more inches lift (size matters) More discussion on reply to other posts. Can't wait to use it. Its getting real hard for me to get up and down.
« Reply #4512 on: October 30, 2019, 06:44:16 AM »
Yes, model 1000 was the main offering. The new one we bot is the SAM 1200. 200 extra lbs plus other features.
« Reply #4513 on: October 30, 2019, 07:01:29 AM »
The 40200 SAM 1200 Air lift is $1060 from Mile-X Equipment. (www.mile-x.com) If you buy direct from Handy its $1376. Buying direct is not the deal.
We bot the Cycle Vise $165, I bot a Handy Dolly which sticks under the end of the lift and raises it so you can roll it around the shop on the wheels. I got the "Deluxe Pole" for $109.
Shipping was $170.49 from Coldwater OH to Indianapolis IN Fed Ex depot. Joe rented a UHaul trailer for about $35 I think and picked them up. He brought mine to me and since I am incapable of effort, he unloaded it in my shop. Backed the trailer right in, impressive. He stripped the box of extra parts, we put some PVC pipe under it and rolled it out on the floor.
I've got a pretty big tank on my compressor, but I'll bet yours will work.
« Reply #4514 on: October 30, 2019, 07:21:59 AM »
Ron great info and thanks for sharing. Looks like a fantastic lift and I actually watched all of that You Tube video I was so mesmerized. Enjoy it!
good luck!
Andy
Offline CBJoe
« Reply #4515 on: November 16, 2019, 01:58:06 PM »
Hey All...Ron and I were looking into adjusting the needles on his VM29 Smoothbores.  Does anyone have some guidance on removing/adjusting the needle positions?  The internets are not being forthcoming with this process...
Joe
'65 CB77
'66 CM91 (C90'ish)
« Reply #4516 on: November 16, 2019, 04:09:19 PM »
carbs off,  throttle shaft out, slide out....yeah, it sucks.  Hopefully, someone pipes up with a faster, easier way.  I would love to know too!  Sometimes Mikuni has the needle clips sandwiched between two plastic washers/spacers.  Be sure to note the arrangement on dis-assembly.
« Reply #4517 on: November 16, 2019, 10:34:29 PM »
I adjusted VM29 needles with carbs on bike.
Tank off, all top covers off, remove the throttle shaft after you have removed all bolts holding it like throttles and the throttle mechanism in the middle. Remove the rubber plugs on both sides.  I ususally moved it out to right. Pushed it out with a screwdriver allen tool with rounded top from left. Grease it a little if it will not slide the the glide bearings. Thin oil spray.
I have replaced all x-screws holding top cover and float bowls with allen head screws so they were easy to remove when carbs sitting on bike.
I did all needles within one hour. I think I managed within 30 minutes too.
I removed float bowls at least 15-20 times without replacing the fiber gaskets.
CB750 stock carbs sucks when it comes to needle adjustments. Carbs off and away from rack.
My TMR is easier to adjust needles, max 30 minutes with tank back on. Throttles not to be removed. I have done it on 20 minutes. I usually double check the needle setting to avoid forgotten needle or clip in wrong notch.
« Last Edit: November 16, 2019, 10:36:21 PM by PeWe »
Offline CBJoe
« Reply #4518 on: November 17, 2019, 07:10:33 AM »
Thanks...This aligns with the little bit of info I found over on some KZ forums.  Bummer...Carbs are already off the bike...so there's that.  Maybe someone will chime in with some Magic Suggestion.  Was really hoping the slides didn't need fully pulled to do the job. Oh Well  ::)
PeWe...you are right...on my RS34's the needle change is extremely easy.
'65 CB77
'66 CM91 (C90'ish)
« Reply #4519 on: November 19, 2019, 09:30:13 AM »
Rats! But its like everything else. Once we put our collective minds to it, we'll persevere and push on.
But we're having fun!. The lift is a great and timely addition. I can't get off the floor anymore. I need some shop stools too. Wife and I bought a Honda Odyssey Conversion with a side ramp. Found a 2017 with 12400 miles on it. Practically new. WE need to get a wheelchair suitable for the rig. That should come this week. I'll have a rear trailer hitch on it. That wasn't in the planned budget and they are pricey.
Re: Phaedrus: CB750 RestoMod - Update: 12/2/19 w/new pics
« Reply #4520 on: December 02, 2019, 08:25:43 AM »
We got the carbs apart. I should say, Joe got them apart. Pulled the rod (forget the name) that hooks them all to the bell crank. Pulled the needles, which were all set on the middle notch of five. Lowered them 1 notch each, to get a little more lean in the middle. Raised the main jet 1 size from 125 to to 127.50, to richen the top end. Next is put it together and back to the Dyno. I want to wire in a pigtail to the ignition so its not so hard to plug it into the the Dyno.
My long term goal now is to get the hp up and get it ready for the VJMC National Show at Spring Mill State Park next year in Mitchell IN in June or July. I may have to scab together a better exhaust. I've got a 4-1 Kerker header but no muffler. I know there are muffler places to shop. So it will be fun.
Pictures and more updates soon.  Got a snarky oil leak hope to get fixed too. Can't tell if its at the crankcase split, the alternator cover or to bearing stand pucks. All are fixable, the lift really helps.
« Last Edit: December 02, 2019, 09:05:48 AM by MCRider »
Offline Tintop
« Reply #4521 on: December 02, 2019, 09:37:24 AM »
Sorry to hear about your continuing mobility issues Ron, but glad to hear Phaedrus' development is moving forward.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline CBJoe
« Reply #4522 on: December 03, 2019, 02:22:00 PM »
Remind me Ron...will that Kerker you have work with the center stand?  If its the same as the Kerker header I have i'm guessing it will.
I can always pull the muffler off my bike for testing on yours  ;D  Then you can make some decisions after seeing numbers.
Joe
'65 CB77
'66 CM91 (C90'ish)
« Reply #4523 on: December 03, 2019, 06:46:45 PM »
A strange question, maybe: when does the intake valve (actually) open (1mm lift) with this cam?
And, what does the air intake system look like?
Offline CBJoe
« Reply #4524 on: December 07, 2019, 04:35:26 PM »
Hey Mark
Running Pod Filters...Not sure about the valve opening...its a CX-7 Cam from Cycle X.  We'll have to check back on the notes from when we timed the cam.
'65 CB77
'66 CM91 (C90'ish)
