Author Topic: Petcock size question  (Read 1763 times)
Offline bunghole
« on: June 20, 2008, 10:20:45 AM »
I'm putting a '73 750K tank on my '77 750K.  I noticed that the petcock from the '77 won't fit the '73.  Does anyone know the size for the screw type petcock for the '73?  Also, I assume it is a single output petcock, no?
Thanks!
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Re: Petcock size question
« Reply #1 on: June 20, 2008, 12:03:38 PM »
73 should have the type held on with 2 screws inside the bowl
Offline bunghole
« Reply #2 on: June 20, 2008, 12:52:34 PM »
Actually, now that I look back at its description from Ebay, it was advertised as a '73 750E.
Here is a pick:
It has a screw on petcock fitting that is larger (working off memory) than the one for the '77.
Thanks!
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline bunghole
« Reply #3 on: June 20, 2008, 10:23:28 PM »
I'm home and measured the petcock outlet and it is 3/4" or 19mm.  Anyone know if this is original or did someone modify the tank?  If original, anyone know a source for a replacement petcock that will fit?
Here's a pic of the outlet:
While we're at it, if anyone can definitively identify the year and model of the tank, that would help alot with tracking down a new cap gasket (no lock on cap if that helps).  Thanks!  Here some pics:
« Last Edit: June 27, 2008, 09:56:36 AM by bunghole »
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
« Reply #4 on: June 21, 2008, 03:58:49 AM »
All i can tell you is definately NOT 73. On the bottom oposite side to the threaded boss is a plate oval pad, if thats been welded on its been modded as thats where the original goes
Offline bunghole
« Reply #5 on: June 21, 2008, 09:01:36 AM »
Huh.  Interesting.  Looks like it was originally a right side petcock that someone changed to work with a 3/4" petcock.  Fits the bike just fine, except for being shorter which is a non issue because I'm going to fab up some sort of cafe seat anyway.
So does anyone know what my options are for a petcock?  I don't need it to be Honda accurate, just leak-free with an on, reserve and off setting.
Thanks!
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline SD750F
    • My Business Site
« Reply #6 on: June 21, 2008, 09:54:42 AM »
My older CB750F3 Super Sport seams to have a 3/8" NPT...??? Or at least that is the only thing I can find that will fit. And yes, it is a tapered or NPT thread. I have heard that Honda did this for the 77 and 78 models, is that correct? So I am having a really fun time finding an after-market Pringel or other make for my project.
Any suggestions???
Scott
Offline chrislib
« Reply #7 on: June 21, 2008, 02:51:07 PM »
pingel...nice but $$$
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline Brantley
  • Drano
« Reply #8 on: June 22, 2008, 10:25:29 PM »
Any suggestions???
Scott
Thanks!
If you guys have a boneyard near you, look for a '75 or '76 CB500t. Those tanks have the same sort of external bung (pardon!), but I'm not sure of the size.
« Last Edit: June 22, 2008, 10:32:40 PM by Brantley »
« Reply #9 on: June 22, 2008, 11:11:05 PM »
Just buy a 76 petcock for the black tank, or machine a fitting (20 min job) to fit what you got.
Pingel if I remember offered an adapter that would convert the 75 & down tanks.. it is easy to make but requires an o-ring groove
Offline bunghole
« Reply #10 on: June 23, 2008, 09:37:06 AM »
Are the '76s 3/4"?  That's how big mine is.  My petcock I mean :).
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline Brantley
  • Drano
« Reply #11 on: June 23, 2008, 10:01:07 AM »
Just measured the 500t. Approx 3/4" O.D. and 3/8" I.D. I would imagine the '76 750 is the same.
Offline bunghole
« Reply #12 on: June 23, 2008, 11:19:05 AM »
That's great!  Thanks for the help everyone and especially Brantley for measuring his.
Off to find one!
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
