Author Topic: Hello from Connecticut  (Read 781 times)
Hendey
« on: June 24, 2008, 02:15:32 PM »
1978 CB750F3  Kerker    K&N pods
Been lurking for a couple of weeks and found this forum very helpful. So now I'm officially registered.
Working on the notorius lean pilot jet issue. (Dam pressed in pilot jets)Currently being addressed by a couple of posts.
Pete
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Re: Hello from Connecticut
« Reply #1 on: June 24, 2008, 06:12:39 PM »
Welcome from Massachusetts.
1974 CB550K
                                  Your 1%er name
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: June 24, 2008, 06:51:30 PM »
Welcome. Post a pic of your bike.
« Reply #3 on: June 24, 2008, 07:24:34 PM »
Welcome from NY, not far from the Ct border. I have a 78k the pressed on jets are really easy to remove. A good plier and wiggle a bit while you pull upward and they pop right out. When you have them clean, line them up and tap back into place.
Hendey
« Reply #4 on: June 25, 2008, 01:31:08 PM »
BobbyR:
Thanks for the info. That gives me the confidence to proceed without screwing things up.
« Reply #5 on: June 26, 2008, 01:59:42 PM »
My pleasure. Just do it patiently and it will be fine. Check the Accel punp. It stores a tiny amount of gas in it, so it can gum up quickly. Just undo the lower screws of the pump and make sure everything is clear.
